0 Members and 1 Guest are viewing this topic. Read 32600 times.
Yes, I agree 100%. I used to use a certain conditioner that I thought was great sonically but it sure did limit dynamics. As many as there are that do limit current there are many consumer and many pro units that do not.
The trick is to find one that works for your system.
That is a real trick with todays prices of $2-6K. You better have a thick wallet too.
This is where one would put their DIY skills to work. Pretty sure one could make a decent one at a fraction of the cost. My tech buddy already has done just that.
I had a heavy duty DIY power conditioner made by an expert for $400. The wall sounded better.
Interesting. What was the problem?
Loss of detail, soundstage, and dynamics. I have an audiophile buddy in St. Louis that has gone through scores of power conditioners also, he has more money than I, and he has found the same problem.I have found on power conditioners to listen to the system for 2-4 weeks with the conditioner, two weeks without, then two weeks with and see which way you prefer. I have preferred without every time.
And this is with all components plugged into the conditioners? Or excluding amps? Not meaning to challenge you here, just to get a clearer idea of what is going on. For me the Running Springs was a great relief in that it didn't limit my dynamics even with the amp plugged in. What a relief.
I don't know if that is reasonable to expect for non-engineering types. Power supply equipment is a DANGEROUS diy! Not for the rank and file. And to achieve the goals of getting it to clean while not harming the sound quality, seems quite difficult to achieve, and unlikely for novices. -Tony
Everything was plugged into the conditioner.
Fair enough, Tom. Hard to say what the issue is there. My first guess would be either a grounding issue using the power conditioner, or some sort of current limiting going on.
If we had a time machine, I'd be curious to know what it sounded like with everything BUT the amp(s) plugged into the conditioners.
Can someone explain in layman's terms how an 1800 watt power conditioner would limit the current (and I assume "dynamics") to a system that draws only 3 or 4 hundred watts? How about 6 hundred?
