VMPS PBS (Powered Bass System) is back
0 Members and 1 Guest are viewing this topic. Read 1934 times.
John Casler
« on: 2 May 2012, 12:11 am »
Sometime ago we had a modded 500/1000wpc amp that we could use for what we called the PBS (Powered Bass System)
That amp, was available to us from an OEM and Big B would tweak it a bit to make it work as he wanted it to with our VMPS FloorStanding Speakers to power the BASS (woofer system) to THUNDEROUS yet harmonically accurate and detailed Low Frequencies.
Quite a few of you have these wonderful systems.  At that time we could offer it as either a Plate Amp, or as a Stackable Component and of course it was a monobloc.
But. . .the OEM eventually changed the amp design so it couldn't easily be modded to hit the frequencies we needed and the PBS fell away. . . until now.
Last Jan we partnered up with Wyred4Sound in Vegas and have been looking over their wonderful line of integrated amps to be put in service for the PBS purposes.  They are a natural.  Lots of power, high damping (2000 @ 100Hz 8ohm), and amperage galore to grip B's WOOFs like they mean it. :lol:
We have the following PBS:
PBS 500 which employs the STI 500 (500wpc to each woofer)
PBS 1000 which employs the STI 1000 (1000wpc to each woofer)
Each amp has a volume control to adjust the Bass system to the blend you like the best for your system, room and listening preferences.
And for you who have been toying with the idea of TUBES on top and SS on the BASS, this is the system 4U.
Also available is the Stereo and Monobloc versions (not integrated) which DO NOT have volume controls so they are only available for those with D-OXO which allows you to perform your balancing inside the D-OXO.
You haven't really heard what your VMPS Floorstanders sound like in the DEEP BASS Underworld until you have strapped 500-1000w on and hit the play button 8)
LOOK OUT! GET DOWN!!
Shortly I will add these to the price list as a VMPS option.  If you have any questions let me know.
« Last Edit: 24 May 2012, 01:04 am by John Casler »
John Casler
Re: VMPS PBS is back
« Reply #1 on: 20 May 2012, 05:25 pm »
As  further update for you VMPS SUBWOOFER owners, fans, or future owners we can also offer the W4S and OEM Monoblocs to blow the sox off your sub.  :o :o
One of the most important things to good clean and clear bass is POWER.
Another is a good DAMPING Factor.
So to that end we have the following SUB AMPS:
1) Our OEM 1000w Sub AMP available in 2 versions  a) Plate amp version and b) Rack Version $549 msrp
Recommended with all subs from 215 up.
2) W4S SX1000 is a 1000w highly musical monobloc (rack mount only requires outboard XO)  $1199 msrp
Check with us for package pricing of sub/amp combos :thumb:
