Binding posts?
0 Members and 1 Guest are viewing this topic. Read 2119 times.
grantc79
Binding posts?
« on: 1 May 2012, 10:48 pm »
What sort of binding posts are on the back of salks speakers?
I need to get some decent cabling and wondering should I get bananas or spades.
Thanks.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
Re: Binding posts?
« Reply #1 on: 1 May 2012, 11:46 pm »
Which speakers?
I'm pretty sure that all of the posts will accept either.  Maybe I can get confirmation on that.  Some have bi-wire capability, some don't (if that matters to you).  I like bananas for the convenience, though some will argue that spades make a more solid connection.
........Peter
won ton on
Re: Binding posts?
« Reply #2 on: 2 May 2012, 12:36 am »
i'm pretty sure my ht2-tl's have cardas binding posts.using bananas on my amp and spades on the speakers,you can tighten up the posts with a wrench as long as you don't overdo it
Saturn94
Re: Binding posts?
« Reply #3 on: 2 May 2012, 04:55 pm »
Thanks.
Or you can go "old school" like me and just use bare wire. :thumb:
repete66211
Re: Binding posts?
« Reply #4 on: 2 May 2012, 05:30 pm »
I once wonderd about this too when I was shopping for my Salks.  Google has a lot of pictures of Salk speakers but for some reason people don't often post pictures of the back side.
pstrisik
Re: Binding posts?
« Reply #5 on: 2 May 2012, 06:02 pm »
If you look at the pricing page for each model it says something about the binding posts.  Most are either "standard five way binding posts" or "premium Cardas binding posts".  Either of those would take spades or bananas or bare wire.
Your HT3s say standard five way.
Here's a fuzzy picture from the back of the SS8 with the premium Cardas.......
........Peter
Austin08
Re: Binding posts?
« Reply #6 on: 2 May 2012, 07:46 pm »
........Peter
Heyhey, stop sneaking into my house to take picture, will you. Hehehe
pstrisik
Re: Binding posts?
« Reply #7 on: 2 May 2012, 08:09 pm »
Ha!  If I didn't have to sneak around, the picture wouldn't be so fuzzy!  :lol:
And it's about time you connected them to an amp!  :jester:
