0 Members and 1 Guest are viewing this topic. Read 18099 times.
Thanks John. I just talked to Jim who tells me the dye is applied and they are applying the sealer coats. Once that is complete, we will look at photos to decide if will will darken any with the top coat. Hopefully done within a couple of weeks!I hope you are enjoying getting yours settled in. What electronics are you running with them?.......Peter
Peter,Hope you get yours soon! I'm using a Luxman 505u integrated with sources: iMac streaming to an Apple TV, through a Bel Canto DAC 2.5, Emotiva ERC-2, and Rega RP-1. Speaker cables are BRM 6 gauge(?) with bananas at both ends. It sounds pretty awesome so far. I'm hearing detail I've never heard before on recordings I'm really familiar with. Oh, and my wife's right, I'd be listening to HT2-TL's right now if she hadn't suggested the step up to the SS8's! Thanks dear.John
New Salks better than the Harbeths and Vivids - whoa, that is quite a comparo and compliment from one who has had all 3!
