Is it possible to use Slim Server 6.2.1 firmware 15 and WPA2-PSK [AES]?
0 Members and 1 Guest are viewing this topic. Read 1058 times.
duff138
 I've been running Slim Server 6.2.1 firmware 15 with my modded Squeezebox for a long time.  Recently switched routers and set up router for XBox 360  using  WPA2-PSK [AES].  Unfortunately Squeezebox version 2 with older firmware doesn't recognize WPA2-PSK [AES].  Can I do anything to get this to work?
srb
It depends on the router, but if your router also has a guest wireless network it can be setup with a different security protocol than the main wireless network.
duff138
worked perfectly.  thanks for the help
