I don't sell the TPA3116... In fact there is no marketing for it besides DIY.All of the engineers of high end gear will tell you design is first, before parts, and parts are the $. There's no $80 transistors in these things.
Am I to assume this is the response of some body who invested in these amps? Do not take it to heart they are still amps. Probably not bad but who cares they are cheap. What did you Expect? Entrance and acceptance into audiophile heaven for $300?
From what I saw in the spec sheet, Crown use 0.5% THD as the point where they decide on the power output rating. The only spec for THD says "< 0.5%". It's not unreasonable to assume that anywhere below the "knee" it's considerably lower.
...I never expected this amp to surpass my Job amp, but for me it does. Some here will prefer the Job. If the Job was $300 and the Crown was $1700, I would still buy the Crown. At very low listening levels, the Crown really takes the cake. I like comparing different amps, and for 300 bucks, I said why not. Life is short, play with as many toys as you can.
Thanks for the comparison. I can only assume I didn't give my 1500 sufficient break in time.
Because I have heard enough Class D and watched it evolve into a legitment powerhouse in amplification. I was expecting a decent spec. When I finally looked at it (not heard) I realized the reality. Do not waist my time with - oh you haven't heard it. I get that - not heard. What's your point?
Anybody trying to build a system should ask me since I do not sell NOTHING. I do not care how much you want to spend and I not interested in your feedback. You should probably learn that very engaging bit of social enlightenment.
Yep, none of this equipment sounds very good unless you break it in properly.
At least this next time around, I will have a pre with high gain, low output impedance, and balanced outputs. So I will be able to play with the Crowns input levels more. And I can always add a tube stage upstream if need be later.
Ok, I will bite. So what speakers and amp do you recommend?
Are you selling Marachino amps?
