0 Members and 1 Guest are viewing this topic. Read 240291 times.
So the iTube is working out well then? no negative impact on detail retrieval?
Also Tom, have you compared attenuating the gain from the Crown vs. using the iTube attenuator to reduce gain? Curious which is more transparent.
I was just thinking all it needs is a tube buffer input, which would allow it to mate with a passive pre easily too. D amps seem to benefit from tubes feeding them. As is the 10k input impedance single ended is a little low too. A couple of 6SN7s would be great, I'm using the 5692 version in my preamp and they give a good full-bodied sound. The connectors could be upgraded but it would be better to find suitable PCB-mount replacements of high quality in the exact same form factor as the stock connectors. There are some options out there... The binding posts could be replaced pretty easy with std posts of higher quality.
That's what I was using with my 1500. Dodds tube buffer (with a 6H30P-DR tube) behind a Goldpoint 25k attenuator. I think the output impedance is around 100 ohms. I though about inserting one of my Jensen tranny converters in there, to use the balanced inputs of the Crown, which has double the input impedance. To see if it would make any difference.I also could of done some tube swapping or even some digital EQing, and probably make the Crown work with my KEFs. I actually still have a couple weeks left in the trial period, and haven't sent it back yet....
Look forward to hearing what else you discover if you take the time to tinker with the amp more. The LS50 is a great speaker, though on the forward side of the spectrum in my experience. I do think that highs do tend to be affected by amp break-in, or you could just be dealing with a characteristic of the amp (maybe other owners could weigh in here). How lean was the Crown + tube buffer combo for you? And how did playing around with the amp gain affect things?
I think that tube buffer may actually not be "tubey" enough for our purposes I do have a souped-up Transcendent grounded grid preamp with nice, rich 12AU7 tubes sitting around, which should pair up nicely with Crown. I'm thinking something like a SAS Labs tubed preamp will also pair up nicely with just enough tube harmonics but still transparent..
I have started to play around with that, but I still want to get more time on the Crown before any serious comparisons.
That's a reason I spoke about modifications to the Crown. There might even be some simple $2 mods that'll bring the forwardness down.
I think the forwardness is primarily a result of the compression, which can't be fixed... but could also be AC power. I'm not so sure the issue with AC power is in the amp though, I'd bet it has to do with other components. The Crown amps PS are supposed to be designed to handle dirty AC power although I have not tested it with or without my PLC yet... it is possible some improvements could be made there.
JK, How lean was the Crown + tube buffer combo for you? Meat on the bones there? I'm thinking of the resonance of a string instrument. And how did playing around with the amp gain affect things?
Tom, how does the Crown compare with the Ncore? The best Class D I have heard to date is the Yamha MX-D1, slightly more dynamic than the Ncore (but both are very good).
