0 Members and 1 Guest are viewing this topic. Read 240365 times.
Dave, I am interested in your thoughts re cable design and pairing with Ncore amplifiers. Because Class D amps all rely on L-C output filters, I would expect that any cables which which exhibit high levels of capacitance or inductance could change the RF profile getting through to the cables. Additionally, I suspect that some cables which exhibit high levels of C or L may even create resonance when combined with the output filter. It would seem wise to use a cable with a balanced level of L and C, and as little of both as possible.Also, since the output filter on Class D amp is never perfect, and high frequency noise does show up on the output, a cable with a geometry designed to limit the antenna effect (to reduce RF broadcast which may be picked up by components and other wires) would seem to be a wise choice for use with class D amplifiers.I have quite a bit of experience with ICE, uCD, and Ncore amps, and I would suggest that anyone auditioning these amps make sure to have them powered up for at least a few hours, if not overnight, before doing any critical listening. Without extended warm up, none of these amps sound their best-often I think quick listening to a cold class D amp is responsible for many negative first impressions.
Frequency Response 10 - 50k Hz +0/-3dB. All loads
Frequency Response 0 50 kHz +0/-3dB. All loads.
That was an incredibly rude personal attack DS-21.
Sorry to be here sharing my experience with class D amps, what is it you're doing here exactly?
I just picked up a used once 2000 off of Ebay for $300. I will compare it to my Job amp running my Zellatons and report back. The Job amp is actually the very first amp on my dirty AC to never me any problems, especially fatiguing headaches.
Class d grabs you at first but is unlistenable long term Had b c and red Dragon
I really wanted to like them.But I was very surprised They were very clean souding.But unemotional
My own Ncore amps sound a lot better with some input wiring changes, for example.
No one would lump all class A/B or class A amplifiers together and characterize their sound one way.
If your comment is for me I could care less I had two of good quality and they didnt stand extended listening. If u find different fine.I could easily say the same to you because of yout liking them.But it seems you dont csre for others opins
jon: I changed the signal input wiring on my Ncores to 21.5 gauge Cardas litz wire, I use this wire a lot for signal path applications.
try some occ silver, 28 gauge, in cotton, in a 8 conductor braid....best I have heard and I have tried a lot...
There are excellent, mediocre, and poor sounding amps of all classes. So, for arguments sake of this thread, let’s stick to the amps that most audiophiles hold in high regard, and compare the merits and challenges of each. For tube amps, would also include DIY, as some of the BEST sounding tube amps I have heard were custom made types.For Class D, the best sounding unit I have heard was the Yamaha MX-D1. The audiophiles I know who have heard it all have been very impressed with its sound. Although it’s not the most recent design, it remains competitive with other more current Class D designs. The MX-D1 has a number of propriety design aspects that makes it an excellent performer. What really gets difficult is how to capture the differences in sonic presentations between any two amps, regardless of operating class. Most all modern amps measure pretty well, and show fairly flat frequency responses into a 8 or 4 ohm resistive load. Yet, we all know that the amps DO sound different from one another. With some speakers, the differences in sound between amps may not be very noticeable. Yet with other speakers, the differences are more pronounced. There have been several lengthy discussions about sound versus measurements over on another Audio website. One of the engineers who participate in the threads stated that he personally did not think the current set of measurements offered up fully captured the sonic presentation from a given amplifier. He thought that measurements could be developed to capture these details, but we currently do not have them available commercially. I have subjectively noticed that the Class D amps that I have owned or heard DO present the music slightly different to other topologies. Some aspects seemed as good as or better than other topologies (such as a clear midrange and vocals), while other aspects were not quite as good (2D vs. 3D, high treble hardness, some listener fatigue). ALL amps deviate (slightly) from absolute neutrality, and the speakers used with the amps have a far great effect on the sound than the amps. Devices like the power cube can provide a better set of measurements of amp performance, but even that doesn’t quite capture the full story of what it is that is heard.
