0 Members and 1 Guest are viewing this topic. Read 237132 times.
Cab:Simply put, if lived up to a 1/4 of the hype, it would be mainstream by now, not just in the DIY world.Jim
I have owned three amps with switching power supplies, and they all sounded 30-40% better running on a battery.I would buy an Ncore in a heartbeat if it ran off of battery.
In doesn't follow that the same must hold true for the ncore....And by the way, it can be run on a battery, it would just be a bit more complicated due to the multiple voltages required...
Tom:I bet you are correct and frankly am miffed why they can't be operated on a battery power supply. Jim
A switching power supply is a swirching power supply no matter what company makes it. My ears are very keen to electronic glare, and all switching power supplies on amps I have ever heard has that same electronic glare.Replace the switching power supply with a battery, and voila!
Cab:The dogma and carp I'm hearing is from you. Others are not personalizing or getting defensive. It's not like you own the company or work for Bruno, but you sure are acting as you do.If they are so good, they will rise on their own merit and not from those who chose to be nebbish in their fervent posts.Jim
So people are excited about this product because it seems to offer heretofore unheard performance at or greatly above its price point. You would think that would appeal to anyone with an interest in this hobby.
Before the net, there has been several great products with unheard performance over the yaers. The dealers just never told you about them. The Musical Fidelity A1 at $375 retail is just one of them. If you heard one of these in your present system today, you would be shocked. They are selling used on Ebay in the $300 range. Not bad since these were made 25 years ago. Now before you make any generalizations, you need to hear one for yourself.
$1900 by the time you get the Ncores assembled in cases is a great value? And what will be the resale value in a couple of years?
Why don't they just put a good linear power supply in it ?
Try listening before you generalize and spread your dogma and your opinion will be taken more seriously....
I am not spreading anything. I am just saying what I hear from SWPS. If you do not hear the electronic glare of SWPS, then you have no worries. Do you work for Hypex?
