Hypex NCore question and answers
0 Members and 1 Guest are viewing this topic. Read 356984 times.
Rclark
Re: Hypex NCore question and answers
« Reply #520 on: 6 Jan 2013, 11:40 pm »
Do it vv, totally worth it.
this_is_vv
« Reply #521 on: 7 Jan 2013, 12:39 am »
yup, AFter months beyond questions changed do i want it or not to....when i am getting this now ...hopefully soon....
V
Chipbyrd
« Reply #522 on: 8 Jan 2013, 01:57 am »
I know this is a bit of a silly question, but can you buy these already assembled?
jtwrace
    • TIPP YouTube Channel
« Reply #523 on: 8 Jan 2013, 02:04 am »
Not from Hypex.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #524 on: 8 Jan 2013, 02:08 am »
3rd parties will. Look in the Industry Ads section of this forum.
Best,
Anand.
Philistine
« Reply #525 on: 9 Jan 2013, 09:29 pm »
Anyone try NCore's with Salk HT3's?  HT3's are power hungry and I'm interested in if they're able to drive them and, if so, how well they perform.
gstew
  • Everything Matters!
« Reply #526 on: 9 Jan 2013, 11:32 pm »
Not the Salks, but I'm using a pair of NC400 to drive a pair of Eminent Technology LFT-IVs at 80db/1watt/1m.
I'm in a small-ish room of roughly 14' x 16' x 9'. And I haven't felt any need for more power, even in comparision with the amps they replaced, a pair of B&O IcePower 1000ASP amps that are rated 1000w-4ohm.
They are doing the job for me!
Greg in Mississippi
Edit: Updated speaker efficiency & room size.
« Last Edit: 10 Jan 2013, 01:12 am by gstew »
jonbee
« Reply #527 on: 9 Jan 2013, 11:39 pm »
I use mine with Selah Tempestas, around 86db/w/m and 4 ohms. They have tons of power and current drive. I've never come close to distorting the amps. I have no doubt they would push the Salks just fine, and sound great doing so.
jtwrace
« Reply #528 on: 9 Jan 2013, 11:53 pm »
"Maxcast" has heard the NC400's on his HT-3's.  See here http://www.audiocircle.com/index.php?topic=105310.msg1106110#msg1106110
this_is_vv
« Reply #529 on: 10 Jan 2013, 05:01 pm »
Just wanted to ask how are these with around 86db sensitivity speaker.....
jtwrace
« Reply #530 on: 10 Jan 2013, 05:02 pm »
No problem.
Did you see this thread?  http://www.audiocircle.com/index.php?topic=105310.0
Regnad
« Reply #531 on: 10 Jan 2013, 05:21 pm »
I have 81dB current-hungry speakers and there is no issue, in fact I have stopped using subs for 2-channel due to the incredible bass control of the NCore.
Philistine
« Reply #532 on: 11 Jan 2013, 12:23 am »
Thanks for the feedback and link to the Salk comments (missed that one).  Looks like I need to try them out with my HT3's  :thumb:
jtwrace
« Reply #533 on: 11 Jan 2013, 12:25 am »
You might post where you're at and maybe someone has a pair that you can try.
http://www.audiocircle.com/index.php?topic=108203.0
DaveX
« Reply #534 on: 12 Jan 2013, 01:28 am »
What is the input sensitivity of the ncores, I thought it was 26db's, I also have a pair of CI D200's which also have 26db's sensitivity, but with the ncores I have to turn up the volume about 2 db's.
poseidonsvoice
« Reply #535 on: 12 Jan 2013, 01:35 am »
You mean voltage gain. Not input sensitivity. In any case, 2 dB difference is peanuts and one shouldn't worry about it, imho.
The voltage gain for the NCore 400 is indeed 26 dB. This is detailed in their pdf file : http://www.hypex.nl/docs/NC400_datasheet.pdf
See Mike Galusha's response here for a detailed understanding of the difference between input sensitivity and voltage gain:
http://www.audiocircle.com/index.php?topic=105438.msg1117228#msg1117228
But to blunt...don't worry...please  :D
Anand.
DaveX
« Reply #536 on: 12 Jan 2013, 02:30 am »
Yes, thanks for the link.
Julf
  • Grumpy second cousin of Mark V Shaney
« Reply #537 on: 12 Jan 2013, 07:57 pm »
And, just to be sure, that means input voltage for full rated output is 2 V.
this_is_vv
« Reply #538 on: 17 Jan 2013, 08:49 pm »
Any test audio recommend for this amp
I plan to listen at very low level at around 50db at night
mgalusha
« Reply #539 on: 17 Jan 2013, 09:14 pm »
Music you like. :)
