Customer feedback 4B SST2
0 Members and 1 Guest are viewing this topic. Read 18358 times.
vegasdave
Re: Customer feedback 4B SST2
« Reply #60 on: 4 Jun 2012, 10:01 pm »
Sounds good! I'm gonna go for either the 7Bs or 28Bs myself!
1oldguy
« Reply #61 on: 5 Jun 2012, 04:23 pm »
My experience with my 4B-SST2 has been good. i have to say finesse, upper frequency clarity and purity is what i want most from my system. And the Bryston exceeded my requirements.
I replaced a Forte'4a and the Bryston is definitely better sounding than the Forte 4a was.
I had that Forte' 4a for about 17 years and it was a hard amp to beat. But the Bryston 4B-SST2 did so easily.
One day if I'm lucky I'll have some one describe me that way.lol :thumb: :thumb:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #62 on: 12 Mar 2013, 03:19 pm »
jbc
Junior Member
Here's some feedback by proxy - my brother just got a Bryston 4B SST2 to power his PMC FB1i signature speakers. Given that I have PMC OB1 speakers (powered by a 5-channel Linn amp), I was curious to hear the amp.
Well, compared to his old amp - which will remain nameless (but was quite similar to mine) - the Bryston was a revelation! The bass control was excellent and the dynamics were opened up considerably, as would be expected by the increases in power and damping factor. More important, however, was the finesse of the midrange. It was smoother, more naturally detailed, and localized images in space with better definition than the old amp.
The 4B is not just a powerhouse, it's a serious audiophile amp. If it were a car, it'd be an Aston Martin.
So now I'm on the lookout for a hundred pounds or so of 6B to power my PMC fronts, and am struggling with whether I should get a 3B surround processor first or the power amp.
Hmmm. Decisions, decisions.
redbook
  • the music is the blood...........
« Reply #63 on: 12 Mar 2013, 04:27 pm »
  I still hope that the 4b will be put out as 2 seperate monoblocks ( 2 chassis) :thumb:
rmurray
« Reply #64 on: 12 Mar 2013, 09:56 pm »
  yes same here :thumb: :thumb: :thumb:
larevoj
« Reply #65 on: 13 Mar 2013, 06:05 am »
Hi Redbook, this is an interesting idea...not radical but maybe something worth looking at in Bryston. I read somewhere here about this but seems to have lost traction particularly with the number new products Bryston have released recently and more to come.
I think a smaller mono with 250W@4Ohms, bigger/better transformer, higher caps values, etc. and each has its own power supply line from the Torus maybe a killer mono for small stand mount or monitor setup. It maybe a 2BSST2 - all good things come in pairs :thumb:
larevoj
« Reply #66 on: 13 Mar 2013, 09:04 am »
Received an msg from Frisco for this pic and I thought why not just share it to everyone whom like a copy of it!  :thumb:
Cheers!
Frisco
« Reply #67 on: 13 Mar 2013, 03:55 pm »
Thank You Sir   :thumb:
rmurray
« Reply #68 on: 14 Mar 2013, 02:40 pm »
  James would it be soo hard to package the 4b 300  sst2 on a regular chassis? It would sit on a shelf with the faeplate and switch front facing :scratch:
« Reply #69 on: 14 Mar 2013, 02:42 pm »
Not hard - just need the time to design and build it.
james
rmurray
« Reply #70 on: 14 Mar 2013, 02:48 pm »
  Thanks James :drool: :bowdown:
« Reply #71 on: 10 Jun 2013, 02:36 pm »
Sent: June-09-13
To: Bryston
A COMMENTARY ON MY LISTENING SESSION with the Bryston 4B SST2 Amplifier.
I set up the 4B SST with the SP-3 via a pair of Zaolla Silver Balanced interconnects.
The Blue Ray was connected via HDMI, as was the DVD (Pioneer Elite ) Universal unit, plus Mogami analogue
The 802's were connected with Rhapsody version  cables, about 10'. Current amps are 250W Mono-blocks , and were/are connected with Mogami Balanced Studio cable  (Same  Straight Wire Interconnects ) All listening was done at moderate levels, at lest for me…under 90 dB peaks, averaging maybe 85   *2…Except one!
First track; Gaucho…DACD DSD recording;  All I can say is that I thought my sub was on and after 2 minutes had to get up and confirm it wasn't.  Shocking at the amount of detail in the lower 2 octaves I heard, and heard musically ! The upper mid-range was [CLEARLY] centered, with a sound stage that sounded dramatically different.
Next I went to something not as complex, but a standard test track of mine as the recording is very clean; Mark Knopfler, Sailing to Phil. What it is; THis time, and I can't stress this enough…I literally had to double check, first my pre-amp setting (PCM in, 2-ch out)…then confirm that somehow the large center speaker I had, and the secondary Speaker bar somehow wasn't getting a signal. I was literally blown away by the sound stage. I have demoed this track at trade shows, setting up people's outdoor systems, and massive indoor audiophile suites. The inky, black hole silence at certain sections was , well, dead quiet.  All I  kept thinking was if this is so quiet, what will the 28B or the 7B SST be like ! The cut with James Taylor really allowed the slight vocal intonations really come out.  It almost made you think he was using a Neumann or other tube mic.
I then went to another extremely well recorded and re-mastered disk, (although I hate to say it )…Ray Charles, Genius Loves Company  DTS DVD & Hi-Def Stereo CD combo. I used the CD so it would be in stereo not surround. Now I know he must have been using a Tube mic…WOW, the breathing, the definition, the depth of field … as much as I always knew these attributes were self evident on this disc, the 4B SST defined everything, and not in a hard edge way, but in a very natural, musical way…LIVE…with staging details like HEIGHT amazingly real. Sounded like they were singing about 5' up…as if the piano was on the stage. Felt the same way with the Diana Krall track, but when I got to, "It was a very good year', with Willie Nelson… They really sounded like they were in the room.   Hey Girl, with Michael McDonald really allowed the smallest,  and shortest of vocal notes to be clearly delineated, but at the same time…musically as part of , not delineated out of his vocals!. Just the slightest of his vibrato was perfect. Mary Ann, with Pancho Sanchez was ALIVE with power and with the added stress of the many timbres of his hands hitting the  skins, ZERO stress, and complete, clear, defined musically tones,  Not mushy or muddy bass tones.
Moving to a test classic, a gift from one of my clients…The gold pressing of Jazz at the Pawnshop, Limehouse Blues; The absolute dead quietness at the start, into the very lowest of SPL, clearly understood, and then the overall musicality I have never heard this track sound better…and I have heard this on everything from $50,000 tubes, to $100,000 CLASS A ESOTERIC AMPS!!!
In the same vein, I moved to The Quintet, Jazz at Masey Hall…GREAT MUSIC, not a great recording…but the umbershire of Dizzy was so clear, and one of my favorite Alto's…Parker was pitch perfect. Mingus' bass was so clean, that you can close your eyes and hear the 'flavor' of the wood.
Switching gears completely, Went to a DVD / CD set of a Live recording of Adele at the Royal Albert Hall. I used the CD disk, again to assure the lower resolution & to make sure no bleed or chance of center ch. effect. WOW,  I MEAN WOW….I have listened to the this disc about 2 times in the BMW, on the [upgrade] Lexicon system, and I think twice, in DVD video format on my system.  I never thought anything but a very good recording.  Now some of the  words that I thought I understood, I REALLY UNDERSTOOD.  The low end was simply amazing…another octave or 1/2 octave that  I was missing, as SO TIGHT, and SO musical, that at once I was please and disappointed
!  I was missing so much with my old set up, I knew instantly that I waited to long to upgrade to the BRYSTON amp!
Then switching to my all time favorite Tenor, Stan Getz, I listened to a number of tracks from Getz & Barron CD…one of his last. Kenny Barron's stand up simply sounded amazing…and the two together…close your eyes are they are playing 12' from you in a small venue !
Wanting to start stressing the amp, I moved to a little more intricate disc, with a lot more bottom end more sizzle at the top with lots of cymbal work; Soul Burst by Cal Tjader;  Very active, very wide, very hot music.  Between the Timbales, Conga and drums, mixed with the vibe..allowed me to really hear  a full work, fast, with a wide frequency range, powerfull and at the same time musically delicate.  Soul Sauce never sounded as defined and musical at the same time. The top end was never 'hot' or bright, and the conga's…you could feel the skins.
Keeping in the same vein, but with a remastered…master…I listened to a GIANT of a track , from a GIANT…Savoy jazz Remastered 20-bit transfer Art Blakey and the Jazz Messengers.
The 4B SST was effortless in reproducing the extremely fast playing.  The cymbal work really showed my something.  Instead of the bright, sometimes harsh output, I heard not just the clear sounds of the wood sticks hitting the cymbal, but the [clear] and ever so gentle nuance of the purpose hitting of different spaces on the cymbal, for ever so delicate changes in tone.  I was actually…amazed !
To take it up a notch in complexity, still sticking with jazz, I moved to very revealing piece, sure to stress any amp; The Buddy Rich Big Band, Keep the Customer Satisfied;
A so-so recording of great music, became an easy to listen to, great piece to demo.  The speed, the attack, the decay, the nuance of his sticks, the delicacy to the sheer, raw power was COMPLETELY in control by the 4BSST.  The transient control was amazing.
Last three tracks sealed the deal, as if there was any concern..>How is this for a change of pace?  Grandmaster Flash, Melle Mel & The Furious Five…DVD-AUDIO Whitelines…Talk about lines !  The depth that I always heard before was brought to a new level, and again, with the extra demands on the amp, seemed it barely was making an effort.
The ultimate test, which I didn't realize until I pushed play, was the next  disc, also DVD-AUdio…DTS ES; I must note that throughout the whole test, I never changed any settings, never moved the volume knob… Now I pushed play and thought I MUST HAVE accidentally raised the volume knob as the low end was , LOW…I mean LOW…And musical
*Not my regular musical play material!*
Insane Clown Posse. I actually started to get nervous, as I never heard my system sound like this…DEEP, POWERFULL & in COMPLETE Control, with the ability to control very quickly the cone motion of the woofer's.  I mean absolute control. Violent music, in more ways than one…but an insane woofer test  that the 4B SST passed with flying colors !
Last, I had to walk out with a smile on a good musical note, so I put in a SACD, DSD version , special recording of the ORIGINAL Sympathy for the Devil… AND I DID RAISE the volume to about 91 dB…and the Stones never sounded better in my home…ever !  Not with Audio Research, NAIM, Denon, Dahlquist, LINN…nothing !  The 4B SST was quite an ear opener….
NOW THE QUESTION is 7BSST or 4BSST ?
Best ,
Wayne
HsvHeelFan
« Reply #72 on: 11 Jun 2013, 12:46 pm »
My 2000-ish 4B-ST.  Actually, I've only heard one other Bryston and it was a Thx rated 4B that I was able to borrow for an audition before I purchased my 4B-ST.  My buddy was using the Thx 4B to drive a center channel array in mono mode.
Replacing a Japanese company Integrated amp with a pre-amp and the Bryston 4B was ear-opening and wallet opening.
HsvHeelFan
spinner
« Reply #73 on: 11 Jun 2013, 03:36 pm »
  Now this was what I needed to read about the the 4Bsst sq. Hopefully I will pull the trigger this year on one but will keep the 4ST  as well. Have there been any recent tweaks to the 4Bsq James?   : :scratch: :thumb:
« Reply #74 on: 11 Jun 2013, 03:55 pm »
Hi
No the 4B has remain very stable from a design standpoint.
james
mkaiser
« Reply #75 on: 6 Jul 2013, 04:11 am »
I guess everyone of us in this forum would love to have a pair!!  :lol:
There are practical considerations when it come to purchasing amplifiers. Example if the system is in the small room, with limited space, and driving a relatively easy to drive speakers or monitors - monos like the 7B or 28B is a little overkill I think.
In such setup a stereo amplifier is the best approach...4BSST2 is the ONE.  :D
Very true, most do not understand or don't care about "Need" from "Want" based on the size of the space they are setting up for their systems. I think this is why a lot of audiophiles are not satisfied with their gears performance is because they are stuffing too big of speakers or amps in spaces that are inappropriate matched and therefore are always looking to "upgrade".
For Example: a kids sized room of say, 10' x 12' room housing a pair of 28's and pair of Paradigm Signature S8's - and the audiophile says it sound remarkable.  :lol:
