Pictures of TOTAL LOW WATT SYSTEMS (pictures and brief sentence-no more)
joessportster
  • Set & Single Driver Bliss
Sean Casper 45 monoblocks, Supra Tek Cabernet 300B DHT Dual output 6sn7, sw1X DAC III STD+, Spatial X-2 Clones using Lii F-15 up top and Eminence alpha 15a for Bass........Source PC Running J-River with FLAC files all down sampled to 44.1 / 16, Using a Border Patrol SEi for DDC usb to spdif conversion....................Simply sublime, Musical & Emotional with ZERO digital ugliness........Best to DATE
Crown XLS 1502 on bass Low pass at 150 Hz
charlieboy
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Halcyons :^) and 604 in an ML-TL-ish box
Details?
dave
planet10
  • Frugal-phile (tm)
    • planet10-hifi
I an well familiar with the Halcyons, i provided EnABLed & matched Alpair 10PeN for a couple pair and showed how they could be biamped — either Curt or Madisound said it couldn’t be done.
So yours are stock.
I was more interested in the 604 box (are teh Altec or GPA?).
dave
charlieboy
Misread... Modded internally a bit but the GPA 604-8H-III's are in a Stonehenge V design.
« Last Edit: 30 Aug 2023, 04:19 am by charlieboy »
charlieboy
SEWE300B
jmolsberg
Oliver Sayes 171a SET
Hey Charlie I will be your next door neighbor.
Fantastique equipments.  :thumb:
hogwylde09
  • No rabbit hole armadillo tunnel
My smallish dining room area. Klipsch CF3 (better stands) I know. Yamamoto A 08-S. Stream Amazon HD only.
The CF4’s have way old vintage Fisher 70a mono’s. There’s a hidden CD player and partially visible Audio Research SP3. <<Definitely not flea watt. The Fisher
That was the Robin Trower LP?
hogwylde09
Yes Bridge of Sighs. Use the TT on the Fisher set up.
CWelsh
My very modest system. Single Pass designed ACA powering Klipsch Forte IIIs. I use a Marantz 1060 as a preamp along with a Bluesound Node 2i Gen 3, Oppo  CD player, and Fluance TT.
Lefatshe
WLM Diva 97dB speakers with Audio Mirror 20w Eargasm (during winter, they run hot) and Berning prototype 1.5w 6UL8 per channel (during summer).
Scott F.
After a nearly 10 year hiatus from SETs, I ditched my Mac n B&W system and went back to my Welborne 300b DRDs. After listening to the Klipsch Cornwall type IV's, I knew they would be a good match, and they are. The new Cornwall's ARE the real deal.
Poultrygeist
Decware powering Zenith alnico, compression horn tweeters and Realistic supers. A class d amp with 70Hz Fmods driving the Alpha H-frames. Source is a 4K Firestick streaming into a HDMI extractor/SMSL SU-9 DAC and monitor. Soft hockey practice pucks provide a cushion between the Zenith upper baffle and bass H-frames.
Poultrygeist
Bottle Head 2a3 mono-blocks powering Lii Audio F-15s while a class D amp with Fmods active x-over powering Eminence Alphas.
Poultrygeist
Full range drivers are Zenith 8's, Zenith 12's, Lowther DX-3, Coral Holey Baskets and Gramophone Sound Master. Bass woofers are 15 inch Alphas and Sansui 16 inch. Amps are Bottle Head 2a3, Dennis Had EL-84 and MiniWatt S-1.
Early B.
8 watts of superpower!
Hey Poultrygeist Iam interested in being your neighbor.
