What speakers work well for low watt amps?
Freo-1
Re: What speakers work well for low watt amps?
« Reply #160 on: 26 Jan 2022, 10:26 pm »
Often, these small amps are SE with high Rout, an amplifier that will be much happier with a loudspeaker with a flattih impedance curves.
I have seen NO measurement of a Klipsch impedance (with the stock XO) that anywhere near stisfies this metric.
They may be efficeint (typically rated about 3 dB than they really are), but not really suite dto a high Rout amplifier.
 Crites does some aftremarket XOs that fix this issue with some Klipsch.
dave
Paul Klipsch often said:  " What this country needs is a good 5 watt amplifier ".  Some of the best sound I've heard with Low Wattage is with high quality SET amps driving modified K-Horns.  Most speakers cannot match the K-Horn dynamics.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #161 on: 26 Jan 2022, 11:12 pm »
You will note "stock” in my comment.
They really need a DSP XO to get any sort of time coherence.
dave
Freo-1
« Reply #162 on: 27 Jan 2022, 12:52 am »
Low Wattage setups often lend themselves to tweaks/modifications.  K-Horns do need modifications to get them to sound their best.  Once modified,  they can provide some serious dynamics with some degree of realism.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #163 on: 27 Jan 2022, 01:25 am »
K-Horns are limited to rooms that have a pair of usable corners in the right place so suited to few. They are also BIG.
dave
Freo-1
« Reply #164 on: 27 Jan 2022, 01:49 am »
Yes. That's why they have great dynamics.  :thumb:
Chazz5
« Reply #165 on: 9 Jan 2024, 05:34 am »
The Spendor A1 speakers are excellent with the FirstWatt F8 amp, rated 25 watts at 8 ohms. There is nothing "electronic" about the sound. They are sealed bookshelf speakers in the BBC tradition (but a modern product, not aping the BBC monitor rules). The system plays as loud as one could want in a room of 75 cubic meters.
« Reply #166 on: 9 Jan 2024, 01:01 pm »
dave
And even then only go down to 40 Hz.
« Reply #167 on: 10 Jan 2024, 02:32 am »
What are the corners requirements to a K-Horn?
Its only clear space?
« Last Edit: 10 Jan 2024, 03:33 am by FullRangeMan »
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #168 on: 10 Jan 2024, 05:58 pm »
The corner extends the size of the mouth of the horn. Other examples are Frugel-Horns, Woden Monoliths, RonHorns…
dave
« Reply #169 on: 11 Jan 2024, 12:56 am »
Nice, thanks 🌻
« Reply #170 on: 13 Jan 2024, 02:10 pm »
Read once that the corners should extend 9 feet for full effect.
donyue
« Reply #171 on: 27 Mar 2024, 12:14 am »
I'm pretty new to the high efficiency speaker low watt amp approach.
That being said I have a new to me pair of Klipsch Lascala Industrial splits.  I need to replace the tweeters because one of them is non-functional, and I intend to replace a few crossover capacitors to bring them up to spec.
I will be driving them with a McIntosh C250 amp, which I know is probably considered high powered for this thread, but the low power tube McIntosh amps are too expensive for me at this time.
Currently I am looking for a good tube pre-amp with a nice phono stage that will pair well with the MC250 to provide me the low volume sound quality that I am after.  Maybe someday in the future I will purchase a low power (less than 30w) tube amp to power my LSI just to see if there is a huge difference or not.  I've been advised that the MC250 sounds very similar to the McIntosh tube amps of the same era.  I will likely be adding one or more powered subwoofers to fill out the bass response below 40 Hz.
« Reply #172 on: 27 Mar 2024, 12:34 am »
Interesting. Thankyou for inform.
