"The World's Best Audio System 2012"
larevoj
Re: "The World's Best Audio System 2012"
« Reply #20 on: 8 Apr 2012, 10:45 am »
Putting the most expensive equipment together does not necessary makes the "Best Audio System".... :nono:
FireGuy
« Reply #21 on: 8 Apr 2012, 12:31 pm »
So true Larejov.  If correct though; these should sound 10 x as better than the Magicos.  And, you'll need cables etc.   You maybe able to negotiate those after shelling out over 6 Mil.
http://www.higherfi.com/spkrlist/ShapeAudio_OrganicHarmony.jpg
