Mac mini controlled with Mac book
0 Members and 1 Guest are viewing this topic. Read 2963 times.
mikeeastman
« on: 6 Apr 2012, 02:54 pm »
I heard that I can control my mini using my Mac book anyone know how I set this up?
mshan
Re: Mac mini controlled with Mac book
« Reply #1 on: 6 Apr 2012, 03:01 pm »
I think you just need to activate and configure Apple Screen Sharing in the Preferences panel:  http://docs.info.apple.com/article.html?path=Mac/10.5/en/14066.html
mikeeastman
« Reply #2 on: 6 Apr 2012, 03:21 pm »
Thank you mshan.
roscoeiii
« Reply #3 on: 6 Apr 2012, 03:37 pm »
Yeah, pretty easy to do. The Mac Mini should show up as a shared computer in the Finder window. Click Share Screen and voila! Run my Mini totally headless, and just go from my MacBook. Can also do this from an iPad, iPhone or Android phone (with the appropriate software installed), but I haven't messed much with that. I also use the Public Folder of computers set up this way to exchange files back and forth.
What I haven't done and would like to do is to see if this screen sharing can be done with the Mac Mini hardwired to the network via Ethernet and my MacBook using the wireless network. Keep meaning to look into that. Right now it is all over WiFi.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #4 on: 6 Apr 2012, 07:07 pm »
I have just that setup (except my MacMini is a dual core G5 tower)
dave
roscoeiii
« Reply #5 on: 6 Apr 2012, 07:26 pm »
So with the Ethernet to your G5, it will still show up as a shared drive on a computer on the wireless network? Anything special you need to do to get this to work? (Think I may need to dig out my ethernet router...)
sachi
« Reply #6 on: 6 Apr 2012, 08:02 pm »
apologies for being a little off topic.
Is there any way to control a MAC Mini remotely via a android tablet or with a Win 7 based laptop?
Is VNC the best option?
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #7 on: 6 Apr 2012, 08:15 pm »
Remote desktop works over the network... so when they are box wireless you have a wireless router somewhere. Remote Desktop doesn't car eif it is wireless or wired. I just recently found i can control/screen share my G5 tower running Tiger as well. It is in the basement and doesn't have wireless. So i have it working across 3 machines with Tiger, Leopard, and Snow Leopard
dave
mikeeastman
« Reply #8 on: 6 Apr 2012, 09:17 pm »
Ok, I have finder window and it shows I'm connected to mini, but it shows public folder and when I open it has a drop box but it won't let me open it. How do I get mini screen to show up on my Mac book screen?
roscoeiii
« Reply #9 on: 6 Apr 2012, 09:52 pm »
At the top of the screen when you click on the shared device there should be a little gray bar that appears, with a button that says "Share Screen." Click that.
Might be a bit different if you have an older OX on your MacBook.
Alternatively, there is should be a program on your computer named "Screen Sharing.app" You will need to figure out what to input when it asks for Host. I wasn't clear exactly what it needed to work that way. I just click "Share Screen" in the Finder window when the shared computer is showing.
mikeeastman
« Reply #10 on: 6 Apr 2012, 09:56 pm »
YEA! thanks! it a bitch being a computer illiterate.
roscoeiii
« Reply #11 on: 6 Apr 2012, 10:04 pm »
Killer. Enjoy.
And I do generally find that there is a bit of a lag on the other computer, so I wouldn't try to got too fast.
Other tip I have is that if you want a larger Screen Sharing window on your MacBook, adjust the monitor settings on your MacMini. IIRC, lower resolution --> bigger Screen Sharing window. But I may have gotten that backwards.
mikeeastman
« Reply #12 on: 6 Apr 2012, 11:29 pm »
Now thats service, you answered my next question before I asked, must be some kind of ESP. :)
 Thanks, Mike
roscoeiii
« Reply #13 on: 6 Apr 2012, 11:48 pm »
I've got your back Mike.
chrisby
« Reply #14 on: 9 Apr 2012, 07:48 pm »
well, aren't computer non-geeks like us what Apple is counting on?  :thumb:
of course we lucky ones can usually find a MacHead when we really need one
