BDP-1 and EE Minimax Hi Rez issues
0 Members and 1 Guest are viewing this topic. Read 767 times.
setamp
« on: 5 Apr 2012, 12:58 pm »
Is anyone using an EE Minimax Dac with their BDP-1?
I have trouble playing 192/24 files as I get only stuttering.  I was told cables would make a difference and they did.  I switched from a Canare BNC to a Downsize BNC and was able to play 192/24 most of the time.  I tried a WyWires AES/EBU and found it to sound great on redbook but would stutter on 192.  Over the weekend, I queued up a 192/24 while playing through AES/EBU and got stuttering so I switched over to BNC and it wouldn't play either.  It was a 192/24 file I had no trouble playing in the past.  I gave up and queued up a 96/24 file and it also stuttered on the cable that in the past would allow 192/24 files to play.
Is anyone using a Minimax dac and if so are you having similar issues with hi rez?
