Get her a Dayton Audio DTA-100a digital amp. It is an awesome little amp.I have one Driving a pair of 6 ohm Monitor Audio S1's 89dB and it plays loud and clear with very good transparency, deep controlled bass and nice treble. It sounds even better paired with a good dac or DAC/Preamp like the Maverick TubeMagic DAC-1. $89 here-http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-383
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-380
Thanks for all of the replys guys.I had looked at the DTA-100a, but it says speakers must be 8 ohm min. My atlantic tech's are 8 ohms, the B*se are 4. I'll see if she's OK with the atlantic tech speakers.Randy
That particular T-amp is disqualified for its really crappy spring-loaded speaker terminals and its wanky look.
Shall we ignore that thanks to your "generosity" you now have the opportunity to upgrade?
