I made a change to the MiniBUSS...
0 Members and 1 Guest are viewing this topic. Read 10340 times.
dBe
    • PI audio group, LLC
Re: I made a change to the MiniBUSS...
« Reply #20 on: 18 May 2012, 07:46 pm »
Dave,
I'm back with another question. If I plug all of my components, including the power amp, into it, will there be any interaction?  For example, if the power amp draws a lot of power for a musical peak, does that impact the power to the other components?  Thanks.
Scott
No more so than they would pulling straight from the wall.  The unit itself is not current limiting.
Dave
HAL
« Reply #21 on: 17 Jul 2012, 01:02 am »
My MiniBUSS arrived while I was at CAF2012.
Here is a picture.  You can see the outline for the top of the IEC connector to the right of the picture.  I took the picture at an angle to keep the glare down and get the location of the input connector.
dBe
« Reply #22 on: 17 Jul 2012, 01:23 am »
Rich,
We would all love to hear about the show.  What rooms had it going on?  How about a new topic?
Dave
HAL
« Reply #23 on: 17 Jul 2012, 01:42 am »
Dave,
Here is the CAF2012 thread that we have been posting comments about the show.
http://www.audiocircle.com/index.php?topic=102557.40
Just go down that page a bit and the comments start.
dBe
« Reply #24 on: 17 Jul 2012, 02:52 am »
Dave,
I need to get out more.  Thanks!   8)
Dave
Early B.
« Reply #25 on: 17 Jul 2012, 03:55 am »
Is there an option to include surge protection?  In my area, I get lots of brown outs.
dBe
« Reply #26 on: 17 Jul 2012, 04:12 am »
Uhmmmmm.  Try this:  http://www.audiocircle.com/index.php?topic=106485.0
Dave
Speedskater
  • Kevin
« Reply #27 on: 17 Jul 2012, 07:26 pm »
"brown outs" are an under-voltage problems.
"surges" are over-voltage problems.
That's not to say that you won't get a surge when the "brown out" ends.
