0 Members and 1 Guest are viewing this topic. Read 8449 times.
If still current, $495 for .5m and $795 for 1m
I am still using a Morrow Audio PH3 phono cable that replaced a Nordost Frey on my old set up and I am very happy. Not tempted to experiment with other wire for the time being.
I will have to give them a closer look. I mistakenly assumed all of the ICs were unshielded.
The rest of my ICs are also from the "3" series but are all balanced so no Eichmann plugs.I believe the PH series might be shielded, hence the separate product grouping even though they are RCA-RCA unless you ask for DIN. Mike is an easy guy to work with so you might drop him a line to confirm. Also, with the 60 day trial period if there are any problems you are only out postage. No affiliation, just happy with his cables.
Ummm..I've been experimenting a little: started out with Signalcable Silver Ref phono cable and matching IC with silver eichmann's: perfect if you have a laid back system but a little zingy if you have a "revealing" system: ie a little forward. Since tried some AR Sound Greenlinks and they work very well: are pseudo balanced as well so helps with the noise floor.When I can afford it I'll go the Auditorium 23.
