Garage music setup amp
0 Members and 1 Guest are viewing this topic. Read 6287 times.
chgolatin2
« on: 27 Mar 2012, 09:54 am »
Looking into different options I'm either going to one of these little amps below.  I have the Dayton Audio B652 6-1/2" 2-Way Bookshelf Speaker, total of 4 speakers 1 on each corner also, I am using Harmon Kardon 3390 Amplifier.  However, that amp itself is too big and large.  Even though it sounds wonderful I am looking to downgrade to a smaller amp.  I am actually amaze how good these lil affordable Dayton Audio speakers sound. Yes, their aren't "Audiophile" quality but for the price and to just work on cars, motorcycles and use them as music shop setup they sure sound damn good, makes my garage ROCK ON!
1) http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-383&utm_source=Bazaarvoiceps
2) http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-812
3) http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-601
So what do you guys think or recommend?  Any experience w any of these?
decal
Re: Garage music setup amp
« Reply #1 on: 27 Mar 2012, 11:54 am »
Why do you want to downgrade? That does not compute !!!! :dunno:
timind
  • permanent vacation
« Reply #2 on: 27 Mar 2012, 01:29 pm »
He wants to downsize, not downgrade.  :wink:
decal
« Reply #3 on: 27 Mar 2012, 02:11 pm »
He said downgrade to a smaller amp. Downgrade and downsize are two entirely different things, at least they are to me!!!!
srb
« Reply #4 on: 27 Mar 2012, 03:39 pm »
I assume each pair of 8 ohm speakers are connected in parallel for a 4 ohm load.  The HK 3390 is rated at 100W/ch @ 4 ohms.
The Dayton DTA-100a is rated at 30W/ch @ 8 ohms (50W/ch rating is at 5% THD) and is cautioned not to use with speakers below 8 ohms.
The Dayton APA150 is rated at 75W/ch @ 4 ohms.
The Audiosource AMP100 is rated 60W/ch @ 4 ohms.
All three choices sound like both a downsize (The AMP100 in depth and height anyway) and a potential downgrade.  For absolute sound quality my money would be on the HK 3390, but if I had to choose one I think the APA150 might come closest to what you have considering your setup is not a nearfield desktop environment.
chgolatin2
« Reply #5 on: 28 Mar 2012, 03:06 am »
Sorry guys I meant downsize not downgrade, I am having an issue w my HK Amp, inside my house the unit does not turn off but when I hook it up in the garage it automatically shuts down and I can't figure the problem out.  All of my outlets are new since its a new garage plus the HK amp is a nice amp and if someone breaks in it would be a nice little present at my expense thats why I want to downsize to a decent cheap setup.
TONEPUB
« Reply #6 on: 28 Mar 2012, 04:31 am »
Marantz 2215...
I.Greyhound Fan
« Reply #7 on: 28 Mar 2012, 04:44 am »
Go with the Dayton DTA-100a.  I have one for a small system in my bedroom driving a pair of Monitor Audio S1 speakers, 6 ohm and 89dB sensitivity.  It sounds great with nice deep controlled bass and good air and transparency.  The sound gets a little edgy when the volume knob is turned up just a smidge past 1/2 way.  It plays plenty loud.  The APA150 does not sound as good as the DTA.
Those Dayton B652 speakers will sound much better if you put some sound dampening material in them.
Here is a nice small T amp with a more power-
http://www.hllyhifi.com/tripath-amplifier/hlly-tamp-90-90w-class-t-amp-amplifier-tripath-ta2022.html
Here's another small amp-
http://www.mav-audio.com/base/product/tube_magic_a1
stereogeek
« Reply #8 on: 28 Mar 2012, 10:17 pm »
  What about one of the Sure amps that PE sells? The 2x100 has great power and sound.It's rated at 4 ohms.With the power supply,it's under a 100 bucks! Definitely cheap and cheerful!!! :green:
Steve :)
fredgarvin
« Reply #9 on: 16 Apr 2012, 06:46 pm »
+1 on the DTA-100a, it really is a great sounding amp.
chgolatin2
« Reply #10 on: 22 Apr 2012, 02:59 pm »
Hey guys, thanks for all the positive feedback~ I would like to remain under $300 more or less under $200 so the Dayton DTA-100a sounds like a good choice.  This is not an high en audio setup, just a garage setup where I can listen to good tones meanwhile I work on various mechanical projects
Thanks again~!
Poultrygeist
« Reply #11 on: 22 Apr 2012, 03:37 pm »
The Dayton DTA-100a is your best choice of the three . I have it as well as the Dayton APA150. I also have the Sure/Meanwell which is better but requires a DIY case.
Doublej
« Reply #12 on: 22 Apr 2012, 06:01 pm »
What about an Emotiva a-100 at $200?
http://news.cnet.com/8301-13645_3-57405240-47/emotivas-sweet-sounding-$219-amplifier/?tag=cnetRiver
Poultrygeist
« Reply #13 on: 22 Apr 2012, 09:18 pm »
My Dayton APA-150 aka Emotiva BPA-1 while a good sub amp is not so great as a stereo amp.
T-amps like the DTA-100a IMO just sound better than conventional amps in the same price range and many that cost a lot more.
chgolatin2
« Reply #14 on: 24 Apr 2012, 12:55 pm »
Steve :)
Who is PE???  Like the $100 provide link plz :thumb:
JohnR
« Reply #15 on: 24 Apr 2012, 01:22 pm »
PE is Parts Express.
chgolatin2
« Reply #16 on: 30 Apr 2012, 04:01 am »
Contacted tech support and sales staff of PE, they recommended the DTA 100A amp :)
Thanks for all the help~
fredgarvin
« Reply #17 on: 30 Apr 2012, 03:32 pm »
I'm sure enjoying mine, I'm letting my headphones get dusty because the speakers sound great now with this little thing.
chgolatin2
« Reply #18 on: 5 May 2012, 03:08 pm »
Sounds good to me~   :thumb:  I'm waiting to pull the plug on one of these lil gems...
