0 Members and 1 Guest are viewing this topic. Read 8353 times.
I wonder if the Jolida "Fusion" tube monoblocks rated at 200w at 8 ohms would be a good match for larger Maggies?
JimThis is very much a matter of preference. If you want the higher SPL, then you need more power. and/or you need subs.A 3.x or a 2.x ribbon will do well being biamped so that the bass has the power and the top have the requisite lower power but highly refined amp. I would be first to admit that most affordable high power amps will not impress you with their imaging, great natural tone, rich textures and air, that is because that is what you lose when you cut corners on parts quality to produce more power at the target price. But for the listener, SPL is part of the sound quality - though we tend to speak of it as a separate critter. Where it places on your list of SQ priorities is very much a personal issue and depends on your music preference and your experience of music along with your listening habits. Some folks use volume to bring out detail that they would otherwise miss, some use overall volume to compensate for a lack of bass extension and they raise it till there is sufficient bass content. Others use volume to obtain a stronger sense of dynamics.
The 2.5's are the same size as the IIIA's, but are 2 way, or 5'10" tall and are said to be only 83db efficient, yet they're easier to drive than the 1.6's. I suspect that my 2.5's are closer to 86db, maybe do in part to the x/o's being upgraded to 2.6 specs. Most of the newer Maggies are around 87db efficient.
One simple solution is to run a ss amp with a tube pre -
I've yet to hear a low (under 100 watt) tube amp push the magnepans to anything realistic. I've had good luck with the ARC REF 150 (could still use more juice though) and the Carver Cherry 180's, but have heard them with the ARC REF 610T's and that was probably the best, albeit rather expensive solution. The Manley 250's I had in for review for a while also did a nice job.
Just as an FYI, there is a Butler 2250 available in the trading post forum...will make your Maggies sing.
