MMG to 1.7
0 Members and 1 Guest are viewing this topic. Read 6838 times.
SteveFord
Re: MMG to 1.7
« Reply #20 on: 25 Mar 2012, 09:25 pm »
12' wide is about what I have the 1.7s in and tweeter in is just fine.
I'm using a small NHT "sub" which is more like the DMW than a real subwoofer.
It won't rattle the floor but my turntable prefers things that way.
medium jim
Re: MMG to 1.7
« Reply #21 on: 25 Mar 2012, 09:33 pm »
Hi Josh:
Thanks for your insight and valuable comments.  I have a 16x15 room and would have no problem with 3.7's.  I had 1.6's (which are basically the same size as the 1.7's), in the same room and felt that I could go a little larger.
Enter the 2.5's which are a good fit for the room. The 3.7's are just a tad bit taller and wider and feel that they would be fine as well.
The OP's room is only 4 feet narrower, which actually makes for a better room acoustically and in my mind could easily handle a pair of 1.7's.
Jim
jk@home
Re: MMG to 1.7
« Reply #22 on: 25 Mar 2012, 10:19 pm »
Yeah, thanks Josh, interesting. I know the larger Mags sound better in a larger room, but we deal with what we got. I run tweets out with the MMGs now, sounds best with the series x-over I use.
josh358
Re: MMG to 1.7
« Reply #23 on: 25 Mar 2012, 11:17 pm »
I'm about to put Tympanis in a 13 x 14 room, so (a) nobody in the world is crazier than me and (b) if they'll work, anything will!
(Actually, the Tympani IVa's turned out to be a more practical choice than the other large Maggies, because they can be used in split configuration, with the double woofer panels against the wall and behind the mid/tweeter panel, which is only 18" wide -- not much wider than my MMG's.)
Rclark
Re: MMG to 1.7
« Reply #24 on: 26 Mar 2012, 06:23 am »
 Thanks you I'm thinking about Tympanis as maybe my bass section.. are Tympanis entirely planar or.. is there a driver section? I'm confused as to what those are exactly... and why Magnepan doesn't still offer this "planar sub".
medium jim
Re: MMG to 1.7
« Reply #25 on: 26 Mar 2012, 03:04 pm »
http://www.integracoustics.com/MUG/MUG/reviews/Stereophile-Tympani4a.pdf
http://www.stereophile.com/floorloudspeakers/673mag
Rclark
Re: MMG to 1.7
« Reply #26 on: 26 Mar 2012, 04:52 pm »
Awesome! Thanks Jim.
josh358
