Speaker audition - Finale
0 Members and 1 Guest are viewing this topic. Read 13826 times.
Chicago
Re: Speaker audition - Finale
« Reply #40 on: 12 May 2012, 12:07 am »
They are the 803 variety.
vegasdave
« Reply #41 on: 12 May 2012, 02:59 am »
Congrats Chicago. How do you like them so far.
Chicago
« Reply #42 on: 12 May 2012, 03:56 am »
Very pleased.  I have rediscovered a number of older CD's and I have been feverishly adding new selections.  I think I am going to box up some of my older CD's because of their poor recording quality.  I have been toying with the idea of hooking up an old tuner.
vegasdave
« Reply #43 on: 12 May 2012, 05:21 am »
Very cool. Sounds good. Do you listen to LPs?
Chicago
« Reply #44 on: 13 May 2012, 01:33 am »
About 10 years ago my youngest son appropriated my turntable and album collection.  About the time I was going to ask for it back my grandson decided it was a great plaything and so much for the turntable.  I have toyed with the idea of buying a new turntable but haven't pulled the trigger.
vegasdave
« Reply #45 on: 13 May 2012, 02:26 am »
Ok, cool. As the resident vinyl nut here, I highly recommend that you do. It doesn't have to be too expensive. I recommend believe it or not, the Technics 1210M5G with Audio-Technica AT150MLX cartridge. This will set you back about $1300, give or take.
Chicago
« Reply #46 on: 13 May 2012, 10:07 pm »
Thanks for the input.  It's not so much the cost of the turntable, but the cost of putting together another LP collection and figuring out where I can conveniently place both the turntable and LP's.  I don't have a dedicated listening room so whatever I do has to fit in my existing cabinet space and pass the critical eye of my better half.
vegasdave
« Reply #47 on: 15 May 2012, 08:42 am »
You're welcome. I see. Well, do what you can. No worries.
