MDF cleanup?
Æ
Re: MDF cleanup?
« Reply #20 on: 23 Mar 2012, 02:41 am »
My opinions are well-formed. If youwant to delve deeper http://www.diyaudio.com/forums/construction-tips/98834-discussion-what-materials-build-speakers-out.html
dave
You still don't get it do you? This discussion is supposed to be about MDF cleanup and formaldehyde worries.
N.B. Like I'm going to go over to your forum where you are a moderator! So you can bully me?
S Clark
Re: MDF cleanup?
« Reply #21 on: 23 Mar 2012, 03:43 am »
We are trying to give advice to  one of our junior members.  Using a term such as "misinformed" don't lead to a helpful discussion- and Dave is very experienced in speaker building and well informed.  That doesn't mean that his opinion cannot be politely challenged.
I don't entirely agree with Dave, and think that describing mdf as a 'poor" material for speaker cabinets, especially in the case of a pair of AV-1 speakers.  Actually, I've built very similar designs with both Danny's woofers and tweeters out of mdf and high density ply, and like the ply slightly better.  However, around here Baltic Birch is pushing $100/sheet and mdf is around $25.  Excellent small cabinets can be made from either when thoroughly braced. Remember our goal of helping advise a fellow member to successfully build his project.  Regardless of preference, the pieces are already cut out of mdf, and it would be silly to throw them out in favor of ply.
Æ
Re: MDF cleanup?
« Reply #22 on: 23 Mar 2012, 04:17 am »
So, how is this for twisted logic? Better to have someone else build them than to have to worry about breathing formaldehyde?
Goodbye DIY.
