bnc-bnc vs. AES/EBU digital
0 Members and 1 Guest are viewing this topic. Read 2441 times.
malpa
« on: 13 Mar 2012, 10:41 pm »
hi,
im using bnc to bnc digital cable between BDP-1 and my dac, and i was thinking to try AES/EBU, would that make any difference in SQ ?.
 if yes, what is the difference.
thanks.
BB
Re: bnc-bnc vs. AES/EBU digital
« Reply #1 on: 23 Mar 2012, 07:29 pm »
Due to the connectors used, BNC-BNC is capable of providing a consistent 75 ohm connection.  But since AES/EBU uses XLR connectors, I don't see how it can ever provide a fully consistent 110 ohms like it claims.   So in theory BNC-BNC is the better connection.   Can someone refute this and provide a reliable source?
But I have seen some BDP-1 reviews that say AES sounds better, while other reviews say BNC sounds better.   I noticed that those preferring BNC claimed it sounded more detailed, while those who preferred AES often talked about the smoothness.
jjc1
« Reply #2 on: 24 Mar 2012, 10:58 pm »
Many threads here on AC on this subject. Search them out.They are very informative.
malpa
« Reply #3 on: 25 Mar 2012, 09:06 am »
thanx, im using bnc-bnc at the moment and im happy with it, i dont think to change to aes/ebu anymore.
i will look at the AC subject more.
