Does the Furman IT Reference 20i do the same thing as your linear power supply?
fado
If it does not - would I plug your linear power supply into the Furman so I have the surge protection or does your unit need to plug directly into a wall outlet to perform properly?
Wayne1
The Furman is a power conditioner for AC line current.
The linear power supplies I build convert the AC to DC. Most linear PS do benefit from good AC conditioning. The Furman has been used with my power supplies at the last few RMAFs.
Personally, I use a Bybee Power Purifier before an modified Equi-Tech balanced conditioner. All the power supplies in my system are plugged into that combination.
fado
