0 Members and 1 Guest are viewing this topic. Read 9824 times.
You don't need two xovers in series with a speaker. If you are already using the Behringer to cross over the woofer to the coax then you already have the behringer in series with the coax and tweeter. Please lose that complicated veiled xover and just use the Behringer in tri-amp mode. You will like the results. I am sure your tube output stage is better than the stock opamp based output stage but the rest of the Behringer needs upgrading or you are not hearing much transparency. The analog input stage is just as bad as the output stage and both the A to D converter and the D to A converter need upgrading to the latest chips. Every single thing in the signal path needs to be top notch or you will not hear what is possible.
