Open baffle speakers
0 Members and 1 Guest are viewing this topic. Read 4172 times.
jostber
« on: 29 Feb 2012, 03:30 pm »
I have a set of open baffle speakers in plywood with a support pole in metal in the back. The baffle is 60 cm in width and the pole is 10 cm. The speakers stand on a wooden floor. Is there a Herbie product that could be used to isolate these, and is it recommended?
Herbie
    • Herbie's Audio Lab
Re: Open baffle speakers
« Reply #1 on: 29 Feb 2012, 04:03 pm »
Hi, jostber. A Herbie's dBNeutralizer-based isolation/decoupling product is recommended between the speaker and floor. I'm not sure what the pole/floor interface is like, so can't recommend a specific product.
Loudspeaker Isolation Products
Herbie's Audio Lab
jostber
« Reply #2 on: 29 Feb 2012, 04:09 pm »
Thanks. :) The pole is also made of wood. The dBNeutralizer products, are these the Little and Giant Fat Gliders?
Herbie
« Reply #3 on: 29 Feb 2012, 06:04 pm »
All the loudspeaker isolation/decoupling products featured on the web page are dBNeutralizer based.
Herbie's Audio Lab
jostber
« Reply #4 on: 6 Nov 2013, 10:57 am »
Is there a specific product that can be used to make the bass more firm on a speaker like this?
Herbie
« Reply #5 on: 6 Nov 2013, 02:08 pm »
By far, the most common comments and feedback we receive regarding our dBNeutralizer-based loudspeaker isolation products is better bass definition. You should get a better-defined, deeply linear and extending bass, with general improvements throughout the audio spectrum.
Herbie's Audio Lab
jostber
« Reply #6 on: 7 Nov 2013, 09:26 am »
Thanks. I did order 6 of the sticky fat dots now. :)
