0 Members and 1 Guest are viewing this topic. Read 22298 times.
I understand these were bought from Pacific Valve but you would have been better off paying much less from a Chinese ebay seller. PV wouldn't even send or sell me a cheap replacement tube socket for one of their amps still under warranty. Hell they couldn't even tell me where I could buy a replacement socket. They bank on the fact that their heavy gear is too expensive to ship back and forth for repairs plus Chinese gear has become more reliable than ever. I'd bet they don't have a tech on staff and any repairs they contract out. Their warranty in my case was meaningless.
I'm sorry, I'm trying to figure out how to answer you PM but somehow I cant see a way to do it. I'm new to the forum and maybe that feature is not yet enabled in my profile.Anyway, I've only had the amp for roughly 2 weeks so I cannot tell you how long the stock 805s or 300Bs will last. I have the 3008C which, unfortunately, you've branded as ugly. Don't worry I'm not offended, as long as my wallet is not the one hurting. This morning I actually put back the stock tubes (Shuguang 805, Full Music 300B, Mullard 12AX7, GE 12AU7) so I can get used to how they sound till I receive my preamp. The 3008C is currently set to run as an integrated amp being fed by a Doge 6 Clarity CD player also from Pacific. This is my first hifi tube amp but I've owned guitar tube amps for many years now so was not surprised at all that such beautiful sound would come out of my Monitor Audio GX300 speakers. My first impression? I was WOWed by the first few CDs that I played.... mostly jazzy, bluesy tunes, Nora Jones, Diana Krall, etc... they were fuller, more depth and body. What else can I say...If can get my wife to sit still and listen to more CDs that she normally doesnt care for, then it must be good. Can't wait to try this setup with a preamp.Are you handy with tube amps? You mean when I roll the stock tubes with NOS tubes then I need to re-bias them? I played them for hours with NOS tubes but didn't really notice any hum or noise. The 805s just runs hot, stock or NOS.Regards.
It seems that you like this amp because you keep poking at it. So why not just buy it and try it for 30 days so you can put an end to your misery. I just received my preamp also from PV... it's the Ming Da 300APS with extended legs which look the same as above you showed in the rack. It came with Svetlana 5U4G rectifier tube, (2) 2A3 and (2) CV181 Treasures from Shuguang.I've been using the 3008C in integrated-amp mode, so switched it to a full-amp mode after I connected the 300APS pre-amp. To my ears, the integrated-amp mode was already good so I almost cancelled my pre-amp order. I'm glad I didn't because this 300APS even made it sound so much better. Listening to Norah Jones, Diana Krall, Seth Macfarlane (who is this guy?) ... we noticed that there was more separation between the singer and the band, the bass was more pronounced. My wife noticed the change immediately and I didn't say a word...because she asked "how much is that?" again. I have the 3008C pair and 300APS set up on top of an audio rack. The 300APS comes with a cage but I don't use it since the tubes aren't as hot as the 805s. The cage is as ugly as the 3008C's cage. But for safety reasons, I always have the cage on the 3008C since the 805s carry 900VDC. You may not like the look of the 3008C but I think it's unique and has to stand on its own, not a copycat to a Cary 805AE. At its price point, that is -- a poor man's price point -- there's nothing like it in the market. To sum it up, if you have $7 dollars ($3 for 3008C, $2 for 300APS, and $2 for Doge6 Clarity), you can be listening to really high-end music (the MA GX300 is an extra $5 dollars). I'm poor so I like to drop those zeros especially when the wife starts asking.Oh, I almost forgot... I think the 805 tubes will hold up to driving the GX300. On the 300APS or 3008C volume dials, with zero volume at 7 oclock, I'm usually listening at between 8 and 9 oclock. Its pretty loud at 10 which I did one time and my neighbors started to bang on the walls -- not fun in apt living.So what are you waiting for? Looks like you'll be drooling forever.... Regards.
@FULLRANGEMANReally? Are you kidding me? So you're not even in the USA? If you're not, then there's no way for you to get these babies from PV. You're only option is to buy from China and modify it yourself - if you're able to, there's high voltages when dealing with valves and capacitors so get your local tech to modify it for you. Sorry man, looks like you'll be drooling forever.... I believe that these 3008C babies are the closest you can get to owning a Cary 805AE or 211FE monos which cost more than double, or triple in price. You might be listening to a SET 300B or 2A3 right now but I'm curious if a SET 300B or 2A3 is in the same league as an 805/845/211 SET. I believe they're not so I'm planning to build a SET 300B just to compare. Regards.
