BRYSTON BHA-1 HEADPHONE AMPLIFIER
Jim Hamley
Re: BRYSTON BHA-1 HEADPHONE AMPLIFIER
« Reply #680 on: 20 Aug 2013, 01:32 am »
BHA-1 Mods?
According to Byston's schematic, there are no input coupling caps but there are four 4700uF NP output coupling caps 3C15, 4C15, 5C15 and 6C15. If the DC offset voltage at the output of the power op-amps is small, it would be interesting to see what, if any, sonic benefits might be realized by shorting out these coupling caps.  If the DC offset is not small, audio quality polypropylene and polystyrene bypass caps could be tried. Or DC servos employed.
Also, it has been alleged that the sound of Bryston power amps can be significantly improved by replacing the current source resistors of the input diff amp pairs with current regulator diodes.  In the BHA-1, there are a number of 34.8K current source resistors 3R2, 3R4, 4R2, 4R4, 5R2, 5R4 and 6R2, 6R4 which, given +/- 20V rails, result in 0.56mA to each diff amp pair.  Each of these resistors could be replaced with a 1N5291 current regulator diode having a dynamic impedance of 1.9MegOhm, a more than 50 times improvement.
If any brave soul (or Bryston Engineeing) tries these mods, please let the rest of us know how they work!
« Last Edit: 17 Sep 2013, 02:36 am by Jim Hamley »
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #681 on: 11 Sep 2013, 04:53 pm »
Sent: September-11-13
To: James Tanner
Subject: Bryston BHA-1 Headphone Amplifier
Dear James,
Attached you'll find the first review in the printed magazine Stereoplay of the Bryston BHA-1 Headphone Amplifier in Germany.
Summary: Reference status.
Edvard will be on the first Can Jam in Europe (Septemer 21 and 22, a trade fair for earphones only, it will take place in Essen/Germany).
Cheers!
Kind regards,
Heinrich,
« Last Edit: 11 Sep 2013, 07:02 pm by James Tanner »
mkaiser
« Reply #682 on: 16 Sep 2013, 06:47 pm »
I'm a little disappointed in the demand and resale value of the BHA-1. I've been trying to sell mine for over 4 months for as much as $350 off new ($1295) and in basically mint condition and I have literally zero interest.
Is this typical of Bryston products? If so you won't see me buying Bryston again. This is pretty frustrating.
Try CAM. Lots of selling on this site. Your price is good and you should fetch $900 for your BHA1. If it had the extra XLR outputs to double as a preamp you could get 1k easily as I did.
http://www.canuckaudiomart.com/
« Reply #683 on: 19 Sep 2013, 03:08 pm »
SUBJECT: German Review of Bryston BHA-1 Headphone Amp
STEREOPLAY
Full Steam Ahead!
High performance amplifiers have always been a domain of Bryston.  With the BHA-1 the Canadian HiFi specialist now turns to the owners of especially high quality head phones
It is surely not presumptive to assert that the majority of headphone jacks in HiFi components represent compromise solutions.  Most of the time the budget is tight and invested in other more sales oriented items, which is why it rarely suffices for truly high quality headphone electronics.  Although with standard solutions, for instance with the popular OP-amplifier chips JRC 4556 from New Japan Radio, quite good results can be attained, there is no doubt that with a separate headphone amp upmarket listeners play in a different league.
Until now only very few specialists devoted themselves to the area of pure headphone amps.  With the worldwide boom, especially with very high quality headphones, this area is now also interesting for larger manufacturers whose primary core competence is building amplifiers. The best example for this is Bryston.  With the BHA-1 (for 1,600 Euro) the Canadian manufacturer now introduces his first full-blown headphone amp.  Stop, that's not quite accurate, since the BHA-1 thanks to its adjustable line outputs can also be used as a line level preamp.  The BHA-1 provides three analog inputs selectable via a toggle switch on the substantial aluminum front panel which accept all types of program sources from smart phones to sound studio mixing consoles.  There is an electronically balanced XLR input, an unbalanced RCA input with RCA jacks as well as a likewise unbalanced input with a 3.5 mm. stereo minijack for mobile equipment.
The Name is the Program:
The abbreviation "BHA-1" stands for "Balanced Headphone Amplifier."  Similarly like a bridged power amplifier which drives loudspeakers, the BHA-1 can handle both headphones of the listener completely ungrounded by means of two opposite phase amplifier sections. (refer to the section Headphone Bridged Amplifiers..." on Page 45)  A prerequisite for this is that both transducers in the headphones can be controlled in balanced mode without the necessity of a ground.  Also "normal" headphones can be connected to the BHA-1 with the usual three pole phono plug; in this case, however, only the non-inverting output stage delivers the music signal.
During the listening test the Bryston BHA-1 showed itself to be absolutely neutral, despite that a multifaceted show-off with raven-black bass.  Thanks to its gigantic power there should never be a loudness or lack of dynamics problem even with the ultra softest headphones.  The headphone transducers would "melt" before the BHA-1 causes distortion.
The comparison between unbalanced and balanced operation was very interesting with the HD 800 which Stereoplay could elegantly carry out thanks to its specially made balanced CH 800S connection cable.  In unbalanced mode the German-Canadian duo played more in the center and altogether a bit more organic, and in balanced mode - thoroughly in a positive sense - somewhat "snappy" and even more emphatic in the bass region, and additionally it seemed spatially somewhat wider.  With balanced operation the impression arose that the overall reproduction succeeded one tick "faster" and more explosive.
According to personal taste one can give preference to both connection modes.  However with objective observation one must concede balanced operation small advantages with a somewhat more businesslike interpretation, while the unbalanced mode in musical regard showed somewhat more boundedness.  The best part is that
with the Bryston BHA-1 both variations can be realized.  Also as a line preamp the Canadian cut a good figure soundwise, the only small weakness was a very high voltage gain (amplification) so that one could really never get beyond the 10 o'clock position with the volume control.
Jürgen Schröder
Stereoplay Test Rating:
•   Measurement Values 9
•   Practical application 8
•   Value 10
•   Sound - Absolute Top Class
Elaborate circuit technology and bridged configuration help the BHA-1 amplifier achieve forceful-clear, compression free sound with exemplary clean bass.  Can supply exorbitant volume intensity - not only in balanced mode.
CAPTIONS:
With an optional Rack Mounting Kit the BHA-1 Headphone Amplifier, thanks  to its 19 inch compatible measurements, can also be mounted in sound studio peripheral racks without any problems.  The backside arranged connections for the line inputs and preamp outputs also simplify the cabling.  The enormously robust steel cabinet deserves the rating "unconditionally road-worthy."
The circuitry of the BHA-1 Headphone Amplifier consists primarily of six discretely built-up (with individual transistors) operational amplifiers, of which two serve as input amplifiers (above), and the other four in channel connected pairs as bridged amplifiers (below).  The analog operating loudness potentiometer from Noble (little blue box) follows in the signal path after the balanced input stage.
Besides the standard wired four pole XLR-4 jack the BHA-1 Headphone Amplifier also offers the connection alternative of two channel separate three pole XLR-3 jacks for headphones that can be operated in balanced mode.  The driving amplifier stages are however the same.
Balanced Headphone Connection:
Headphones which are suitable for balanced connection to appropriately operating head-phone amplifiers are recognizable inasmuch as then both transducers, comparable to phono cartridges, require one plus and one minus connection as separate channels.  Accordingly a balanced headphone cable must have four inner conductors, which likewise may have no connection to each other.
High quality headphones often already incorporate quadripolar connection cables, where-in the minus connection of both channels is often connected to the ground contact (rear, broad area of barrel) of a conventional phono plug.  If one wants to rebuild such a cable for balanced usage, it is recommended that a four pole XLR plug be soldered according to the following schematic diagram:
Bridged Headphone Amplifiers - Why?:
Fully bridged- or Bridge-Terminated-Load-Amplifiers (abbreviated: BTL) consist of two amplifiers per channel, one of which outputs a normal, the other a 180 degree turned (inverted) input signal.  Although bridged amplifiers - no matter whether for headphones or loudspeakers - are not principally superior to conventional amplifiers they do offer so to speak inherently two constructive plus points: By means of the opposite phase method of operation, from the inverting and non-inverting bridge branch, they can supply very high output levels even with relatively low supply voltages, which in turn produce high, undistorted maximum volume levels even when connected to difficult to operate, high resistance headphones with impedances over 300 ohms.  A further advantage of bridged amplifiers is that the load (headphones, loudspeakers) remains balanced and not grounded, i.e. it floats between the inverting and non-inverting amplifier output.  Consequently with bridged amplifiers the electrical floating ground as a point of reference is irrelevant since the load is now transferred back and forth between the modulated positive and negative supply voltages.  Attributable to  its floating output signal, bridged amplifiers are inherently less susceptible to load dependent crosstalk, which can easily occur with single ended amplifiers.  The reason for this is as follows: If the load current flows over the floating ground on the way back to the power supply, then because of a not infinitesimal conductor resistance a voltage drop occurs, which modulates the reference point of the entire circuitry dependent on the size of the signal.  If the left and the right channel split the floating ground which is especially the case with headphone amplifiers because of their three pole phono jacks, then channel crosstalk can occur.  Therefore well thought out and in addition low resistance ground routing is the first commandment for normal headphone amplifiers.  However the ground free operation of bridged headphone amplifiers requires that the headphones being used are connected with a four conductor cable to the output.
Translated from the German by Peter Ullman
dodgy
« Reply #684 on: 20 Sep 2013, 10:58 am »
The BHA-1 is bedding in nicely. There is not a lot of Bryston here in NZ, but I have the BDA-2 to keep it company. Sounding very good so far. I upgraded to Valhalla from Tyr before upgrading the DAC.
It does not quite sound as organic as my last DAC, but that may just me getting used to the more forward nature. Certainly all smiles so far  :D
I re-terminated the standard HD-800, awaiting an upgrade in the mail.
Vipers
« Reply #685 on: 14 Oct 2013, 08:37 am »
Hi Guys,
Considering how fantastic the Audeze LCD-2's and LCD-2's sound with the BHA-1 it is really exciting news that Audeze are just about to extend their range of high end headphones with 2 more models, the LCD-X and LCD-X.
The LCD-XC being quite an interesting addition as it is the brands first closed back design, making it the first Planar Magnetic Headphone that is closed back, that I am aware of anyway.
Both the LCD-X and LCD-XC feature new driver designs called Fazor Technology which uses a thinner and lighter membrane which should produce a faster and more insightful presentation, they will certainly be fascinating to listen to once released.
They both look extremely stylish I have to say, with the LCD-X finished in anodized aluminium in gun-metal gray in black lambskin and the LCD-XC finished in black lambskin, gun metal gray aluminium enclosure with a choice of 4 wood cups, Iroki, Walnut, Purple Hear, Bubinga, please see pic below.
Looking on Audeze's website the new models are due over the next month with prices nearer the the LCD-3's, so not cheap, but I bet they are going to work a treat with the BHA-1, got mine on order so will update once they are with me :)
Here are a few pictures -
Audeze LCD-X
Audeze LCD-XC
Paul.
Marius
« Reply #686 on: 15 Oct 2013, 10:58 am »
Hi Paul,
Great news!
Just what I am looking for these last few months. A closed audiophile, balanced headphone. My family would love me for that. I would be able to use the omnipotent BHA1 so much more. I tend to get these aggressive looks now and then using the HD800.....
Let us know how they sound, and, feel. I've still to encounter a set of headphones with the same comfort as the HD800. Other than the good old Jecklin Floats, which are out of production unfortunately. they sounded like no other..
Marius
Hi Guys,
Audeze LCD-X
Audeze LCD-XC
Paul.
Zolty
BRYSTON BHA-1 HEADPHONE AMPLIFIER + HD-800
« Reply #687 on: 15 Oct 2013, 11:53 pm »
Well, my first post on this forum - although I've been reading this thread for a while.
A few weeks ago I bought BHA-1 and paired it with HD-800. Sound was so nice (although not yet perfect - working on cables), that I jumped head forward and bought second-hand BCD-1. I am sold to Bryston sound, and will be more when I switch cabling from RCA to balanced on both ends of BHA-1.
Just two things bother me - after reading how powerful BHA-1 is, I am finding myself listening with volume at 4-5 o'clock (un-balanced connections and with low gain setting). Am I deaf (might be the case ;) ), or is there something wrong with my BHA-1, or maybe that's how it is?
I know that high gain would help, but... unfortunately I can hear the SQ difference between high and low gain settings.
BTW Brystons are great sounding equipment, I wish I had suitable room to use pre+power amps+ some decent (ATC?) speakers.
Grit
  • - Garrett
« Reply #688 on: 16 Oct 2013, 07:59 am »
You might consider wiring your headphones to use the XLR/balanced connector (if they are not already). That'll gain you some loudness.
I'm running Audeze LCD-2's and I've never (on low gain) had to go past about 1-2 o'clock on the dial, and that's for older recordings.
Zolty
« Reply #689 on: 16 Oct 2013, 05:26 pm »
Thanks Grit. I am planning to go balanced both ends - tested a few XLR ICs between CDP-1 and BHA-1. Enjoyed only one of them - Organic Audio (copper). Unfortunately none of the balanced cables for HD800 are easily available so I'll most probably purchase something from abroad without testing.
On the note side - since the CDP-1 arrived without power cord, I borrowed a few from friendly shop and had a chance to play/compare.
While I could hear very slight difference between them when connecting CDP-1, but the difference was quite obvious when changing power cords on BHA-1. Very surprising to 'power cord difference' non-believer which I used to be. ;)
(Sorry for potentially opening can of worms with above statement) ;)
R. Daneel
« Reply #690 on: 16 Oct 2013, 06:19 pm »
The new LCD-X should be more neutral than either LCD-2 or -3 and that is something I could use. The reason I stayed away from Audez'e headphones is their rather dry nature which makes them unsuitable for classical. I think HD800 are still top notch but with more driven genres except progressive ones, I think Audez'e might be more suitable. The hassle is, they don't come cheap and they are nowhere to be had in Croatia and paying more a grand Euro for something I never listened to seems pretty silly.
R. Daneel
« Reply #691 on: 16 Oct 2013, 06:23 pm »
It would be really cool if Pass Labs decided to make a headphone amplifier. Owning both the Bryston and Pass would be a dream come true.
Grit
  • - Garrett
« Reply #692 on: 17 Oct 2013, 04:03 am »
I purchased a more expensive XLR for my Audeze. However, I also got greedy and just made my own. If you don't mind cutting the 1/4" phono plug, confirming continuity with a meter, and doing some very light soldering, you can alter your own cable for just a few dollars. While it won't change the physics of the cable, it will give you a balanced input. Bryston was kind enough to include the pin-out assignments in the BHA-1 documentation, so it was pretty easy.
Grit
  • - Garrett
« Reply #693 on: 17 Oct 2013, 04:09 am »
I loved my Sennheiser's more than anything. Ever. Most comfortable headphones I've ever worn. I tried to replace them with the HD700's, and I just didn't love the sound. It was very revealing, but that wasn't as nice as you'd hope. I imagine for classical music (where I read they shine), that'd be be great. For everything else I listen to though, it drew my attention to each instrument, too much. As a result, I never enjoyed the music. I had a similar experience with HiFi-Man HE-500's. The Audeze LCD-2's finally got me what I really hoped for. My final test: I was "dancing" in my chair when using the Audeze's, just because I was enjoying the music.
I only offer up my opinion because, however you relate it to your own preferences, it may help make your choice easier.
myview
Re: BRYSTON BHA-1 HEADPHONE AMPLIFIER + HD-800
« Reply #694 on: 17 Oct 2013, 05:26 am »
I also use a HD800 (balanced terminated with 2 x 3-pin XLR) with the BHA-1.  FWIW, with 'low gain' setting, my volume dial is usually between 8 and 9 o'clock.  I listen to mainly classical music (a mix of chamber and large-scale orchestral works) and some jazz.  Even with the notoriously difficult-to-drive HE-6, on 'high gain' setting, the volume dial seldom goes beyond 10 o'clock.  4-5 o'clock will be deafeningly loud, I'd imagine.  Or perhaps you just prefer your music LOUD! :P
Zolty
« Reply #695 on: 17 Oct 2013, 05:30 am »
LCD 2.2 were on my short list as well, in fact they were #1, but there is no Audeze dealer/rep in Poland - so it would be a "blind date" buying them.
I borrowed HD800 and T-1 from local shop for a weekend , and out of the two I preferred HD800 much better.
I have some complaints from my "better half" as HD800 are very "open" - so when I listen to music she is forced to listen to it wanting or not.
With BCD/BHA/HD800 combination music gets very engaging, not perfect match for laid back listening. I do enjoy this "surgery of the sound" (for now), but it is more like being in the middle of filharmonic orchestra than sitting in back rows.
I shall wait for closed type Audezes and money permitting purchase LCD-XC - while it is hard to place ATC and Sonus Faber speakers in one room and keep reconnecting them to match music and listeners mood, it is very easy to enjoy the best of both words with headphones.
My manual skills are 1/10, but may try to have the connector replaced with XLR.
I do like the music loud - with HD800, they sound dull/grey when not fed with wats.
Grit
  • - Garrett
« Reply #696 on: 17 Oct 2013, 05:58 am »
If you take a crack at the XLR connector, buy two or three Neutrik connectors so you have 1 or 2 to test on, and buy some cheap wire. This way, you can test the process out BEFORE you cut your headphone cable and try to solder them. I botched my first one, but with 4 connectors on each XLR, I had 4 chances to learn. By the time I did my actual headphones (2nd connector), my soldering was almost beautiful. Just don't let your first attempt be on your headphones cables. :)
Zolty
« Reply #697 on: 17 Oct 2013, 05:17 pm »
Safety First! - I'll have it done by somebody else, it will save me buying next cable ;)
rob80b
« Reply #698 on: 23 Oct 2013, 09:28 pm »
Thinking of finally changing my current head-fi set-up, B60R and 2BLP pro, next month with the BHA-1 as a birthday gift to myself.
Funny I asked James about the possibility of making a headphone amp almost 10 years ago, http://www.audiocircle.com/index.php?topic=13425 ,but it hasn’t really been a priority for a while, but now that my son is a teen I’m back to phones but for different reasons.
Anyway curious if anyone has any insight on the AKG K701s paired with the BHA-1 (especially when listening to vinyl) as I’m currently using the 2BLP pro’s headphone output which offers more than enough power for most inefficient phones , the B60R is fine for the Grados and passable with the Senns but runs out of steam with the 701/501s, I’m hoping the BHA-1 will replace both.
As I use headphones when required at night for music (CD and Vinyl) and movies, I’ll loose the ability to switch between sources but I’ll just reconfigure the pre at the front of the room to handle that.
