BRYSTON BHA-1 HEADPHONE AMPLIFIER
0 Members and 1 Guest are viewing this topic. Read 607006 times.
yyz
Re: BRYSTON BHA-1 HEADPHONE AMPLIFIER
« Reply #1220 on: 22 Jun 2020, 05:45 pm »
All balanced.
The Meze Empy will use a 4 pin XLR on the BHA-1
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1221 on: 22 Jun 2020, 06:18 pm »
AH OK thanks.
james
yyz
« Reply #1222 on: 22 Jun 2020, 06:25 pm »
Can you tell me who I need to contact to initiate the process?
« Reply #1223 on: 22 Jun 2020, 06:56 pm »
Hi
Yes please contact Mike at Bryston - [email protected]
What dealer are you purchasing it from?
james
yyz
« Reply #1224 on: 22 Jun 2020, 06:58 pm »
This is used unit that was purchased from a dealer in Montreal, Quebec. I will have the receipt.
dmdm
« Reply #1225 on: 6 Jul 2020, 07:30 pm »
I never heard back concerning the abyss 1266 tcs. I ordered a second bha1 through simcoe audio a couple weeks back so I'm hoping they will be sufficient. The bha1 sounds great with my clears, empys, lcd 4, hd600s, sony z1r, and lcd xc btw. James, could you tell me if the bha1 has enough juice for the 1266s please.
yyz
« Reply #1226 on: 6 Jul 2020, 07:35 pm »
@dmdm  While my BHA-1 is getting the mods done at the Bryston factory. I was wondering how to set this unit up. Do you have it plugged in directly to a wall socket or some power conditioner?
dmdm
« Reply #1227 on: 6 Jul 2020, 07:37 pm »
I have it plugged into a Richard Gray 600s power conditioner with the bda3.
dmdm
« Reply #1228 on: 1 Aug 2020, 12:10 am »
So no one seems to reply to this dead thread, but I'll give it a shot. I have 2 bha1 amps. One I received today and one from 2017. The first has a lot lower gain than the new one. The volume is pretty much static from 10 to 2 and I need to crank it to 3 o'clock on low gain for similar volume on the new one at its 10 o'clock on low gain. Also, the new one's volume is progressively louder throughout the dial.   The older one is driven by a benchmark dac3b and the new one a bda3.  The benchmark jumpers are at 0 gain. Any thoughts?
yyz
« Reply #1229 on: 1 Aug 2020, 12:32 am »
The volume control on my unit also is stuck at a very low position since it gets way too loud as I turn it up. I am around 10 O'clock position, not happy about that, but not a deal breaker.
Byrston BHA-1 Serial # 1334
I used XLR cable and I am testing this out at the moment with a Benchmark DAC3B.
I am actually doing a shootout with the Benchmark HPA4.
dmdm
« Reply #1230 on: 1 Aug 2020, 12:34 am »
No you misunderstand,  I like the volume of the new one. How do I get the older one louder like the new one?
yyz
« Reply #1231 on: 1 Aug 2020, 12:35 am »
Maybe we should trade units   :D
dmdm
« Reply #1232 on: 1 Aug 2020, 12:47 am »
I guess I just have to have the volume at 90 percent on the older one and I'm assuming this wont hurt the amp.
mav52
« Reply #1233 on: 1 Aug 2020, 02:41 pm »
Question for James, can a black faceplate be purchased to replace the silver ?? if so whom do I call and how much is it and should I send it in for replacement ?  the model was manufacturer in 2015.
« Reply #1234 on: 1 Aug 2020, 03:41 pm »
Contact Mike - [email protected]
james
mav52
« Reply #1235 on: 1 Aug 2020, 04:26 pm »
james
Thank You , email sent to Mike.
mav52
« Reply #1236 on: 6 Aug 2020, 11:24 pm »
james
James do you know is Mike back, Still waiting on an answer.
« Reply #1237 on: 7 Aug 2020, 12:54 am »
I think so but I know he is out tomorrow - email Brian - [email protected]
james
schugh
« Reply #1238 on: 20 Aug 2020, 10:30 pm »
Lately the volume knob sometimes is noisy as there is crackling from the speakers or headphones connected to it.
Is there anything I can do myself to try and resolve this without having to send it in?
Also if I turn the volume knob up and down a few times it eventually stops being noisy, but then if I don't use it for a couple of days or so, it does it again.
-- Sanjay
R. Daneel
« Reply #1239 on: 20 Aug 2020, 10:43 pm »
-- Sanjay
Hi Samjay!
You might try removing the pot from the shaft (there is only one screw that holds it in place) and use a very small amount of WD-40 or some specialized agent for electrical contact rejuvenation. I found this to be the case with my BHA-1 which is a very early S/N unit. Lots of things can contribute to this and in my case, it is extremely high humditiy where I live. 97% relative humidity at +40C can't be a good thing for anyone or anything, can it?
Most conventional volume potentiometers are like this and they require frequent use and in some cases, periodic maintenance.
Antun
