BRYSTON BHA-1 HEADPHONE AMPLIFIER
zoom25
Re: BRYSTON BHA-1 HEADPHONE AMPLIFIER
« Reply #1040 on: 19 Jan 2017, 07:55 pm »
Hi
It has been that price for about 6 months now.
james
$1295...$1395...$1695...$1950
After looking around. Indeed.
zoom25
« Reply #1041 on: 19 Jan 2017, 07:56 pm »
After getting good results with HD 800 through Sonarworks calibration, might seriously consider the BHA-1 and other neutral SS amps.
CanadianMaestro
« Reply #1042 on: 19 Jan 2017, 09:02 pm »
What are you using so far -- tubed amp?
zoom25
« Reply #1043 on: 19 Jan 2017, 09:11 pm »
Right now just using them straight out of the Dangerous Music Source's built in headphone amplifier. In the past I had other headphone and amps, but sold them off because I went to speakers. Then I heard the HD 800 and figured it might be worth building a headphone rig around one.
Before Sonarworks, I thought I might try a tube to tame the high end. Although, I am not too fond of tubes. I like to leave my components ON and not worry about accidentally leaving them on for too long and damaging them. Solid state is easier to live with.
CanadianMaestro
« Reply #1044 on: 19 Jan 2017, 10:01 pm »
Try the Project Polaris. I have it, it's beautiful -- just a touch of tubular warmth without the tubes. Tons of power too. And adjustable gains and freq attenuation. The clear acrylic casing is amusing -- you see everything.
Pundamilia
« Reply #1045 on: 20 Jan 2017, 12:35 am »
The Home Theater Hi-Fi review alludes to a comparison between the BHA-1 and the BP-25: "It also worked really well inserted in my studio 2 channel rig for a short stint, providing a welcome upgrade in sound over the onboard headphone jack in my own Bryston BP-25 preamplifier". Has anyone tried a systematic comparison between the BHA-1 and the HP jack from the BP25/26?
@James: Are the circuits significantly different? Are they both Class A?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1046 on: 20 Jan 2017, 01:05 am »
Hi
Yes they are totally different circuits.  The BP25/26 headphone amp is a very low power unit designed for fairly easy to drive headphones and single ended whereas the  BHA-1 is a 'take no prisoner' design with balanced circuitry.
james
Brinn
« Reply #1047 on: 6 Feb 2017, 06:29 pm »
Hello,
Sorry if this has been addressed before, but there are just too many pages to go through. I have an opportunity to purchase a used/demo BHA-1 from a dealer, but I noticed that it's a very early model and looks different than the newer BHA-1. It lacks Balanced outs and the toggle switches seems to be different. I have no need to use the BHA-1 as a preamp. Is the sound-quality about par with newer models? Are there other differences I should know about? Thank you.
« Reply #1048 on: 7 Feb 2017, 12:42 am »
Hello,
Hi Brinn
Yes the XLR outputs were added after SN 50 but all else is the same.
james
schugh
« Reply #1049 on: 28 Feb 2017, 07:19 pm »
I have a question about the specs which I've always been a bit confused about when I look at them on the Bryston web site.
On the web site it shows this type of information at different loads.
Load @ 600 Ohms
Hi - 10.9V Out @ 001% Power 200 mW
Lo - 5.45 V Out @ 001% Power 50 mW
Lo - 2.50 V Out @ 001% Power 10 mW
Lo - 788 mV Out @ 001%¹ Power 1 mW
Is the Hi setting when the gain switch is in the high position?
Why are there three different Lo specifications? How do I know which one applies to my unit?
What difference does does it make to the numbers if I use the balanced input and balanced output?
Thanks.
CanadianMaestro
« Reply #1050 on: 28 Feb 2017, 11:46 pm »
^ here are some numbers I had on my audioblog, taken from Bryston a while back.
Power (continuous):
Max: 2 W/chan into 32 ohms @ 1% THD
Rated: 500 mW/chan into 32 ohms @ 0.005% THD
Also this:
http://bryston.com/PDF/brochures/BHA1_BROCHURE.pdf
That imo, is plenty of juice to drive anything under the sun, at a modest load.
Actual output may be even higher than stated.
Bryston should chime in here to correct or comment.
rob80b
« Reply #1051 on: 21 Jun 2017, 08:57 pm »
Another great combo IMHO...AKG K812s....adds that little extra something over my Sennheiser HD800S...with regards to clarity, layering and base definition.
95Dyna
« Reply #1052 on: 17 Jul 2017, 03:41 am »
Has anyone heard the new Grado PS2000e with the BHA-1?
shawngt2
« Reply #1053 on: 28 Oct 2017, 02:05 pm »
Hi Rob, How do you find the SE vs Balanced connection with the 800S. Would there be a significant audible difference in blind test?
95Dyna
« Reply #1054 on: 30 Oct 2017, 08:30 pm »
Since nobody responded to my post in July I'll respond to it myself, I have  :lol: Just installed my new BHA-1 and Grado PS 2000e's and can report that after a couple hours I became addicted.  My Focal Sopra 2's are getting a well deserved vacation and I'm not sure when they will return.  This combo sounded fantastic right out of the box even using a garden variety Monster single ended IC from BP26 tape out > BHA-1. Unbelievable balance from top to bottom with deep refined bass and extra-cranial 3D soundstage. I had the Cardas Clear HP cable installed at the Grado factory with 4 pin balanced connector.  Can't wait to get a few hundred hours on the phones and cable.  Plan to try balanced connection directly from Esoteric K-05 > BHA-1 this week.
CanadianMaestro
« Reply #1056 on: 2 Dec 2017, 01:17 pm »
95Dyna
« Reply #1057 on: 2 Dec 2017, 10:50 pm »
https://www.audioaficionado.org/showpost.php?p=882893&postcount=1
+1
Picking up on my post just above I switched to a pair of balanced WireWorld Silver Eclipse 6's from Esoteric K-05>BHA-1 and it too took the Grado PS2000e's to another level of clarity, spaciousness and definition (and they were good to begin with).  As mentioned I'm using the Cardas Clear 4 pin balanced cable from BHA>Grado.  If you haven't checked out the PS2000e I highly recommend you do so if you ae in the market in the $2-4K range. They are a great match for the BHA-1.
CanadianMaestro
« Reply #1058 on: 4 Dec 2017, 12:32 pm »
+1
Nice upgrade.  Curious: what benefits did the Clear XLR cable bring to your listening? Versus say, something like a Blue Dragon (Moon Audio) or even a Canare cable (Take Five Audio)? The Clear can co$t more than some headphones.  :roll:
cheers
95Dyna
« Reply #1059 on: 6 Dec 2017, 12:06 am »
cheers
I didn't have the opportunity to audition various cables to compare to the Clear.  I just retired recently and wanted to get a top notch HP setup that would outlast me. :D  The Cardas Clear seemed to me after reading a multitude of reviews to be universally accepted as one of the few best.  I had it boiled down to the WireWorld  Nano Silver Eclipse (all my other cables are WW) and the Moon Black Dragon.  My dealer made me a deal on the Grado/BHA-1/Cardas combo that was hard to pass up.  My cable is 4 m and cost about 1/4th the cost of the headphones.  Another consideration was the level of headphones that are the PS2000e's I wanted to pair them with an amp and cable that would be of equal caliber..  All I can say is the setup is fabulous and I'm not looking back.
