A good budget DAC for a nightshade amp?
ProCast99
« on: 27 Feb 2012, 04:21 am »
Hi all:
I am looking to get a good-sounding DAC in the $250 - 500 range - any thoughts about what kind has gone well with Nightshade amps?
I know Blair does some computer type work - any special insights, Blair?
Thx!
gooberdude
Re: A good budget DAC for a nightshade amp?
« Reply #1 on: 27 Feb 2012, 04:33 am »
I have the grant fidelity dac-11 paired with an NS-15 SET amp.  Works great.  Lots of inputs.
Niteshade
    • Niteshade Audio
« Reply #2 on: 27 Feb 2012, 10:28 am »
Look here: http://www.amazon.com/Behringer-UFO202-Audio-Interface/dp/B002GHBYZ0/ref=pd_cp_MI_1
A good place to start! I think they work extremely well.
lokie
« Reply #3 on: 27 Feb 2012, 12:34 pm »
This looks interesting. A little expensive but interesting.
http://www.halidedesign.com/dachd/
InfernoSTi
« Reply #4 on: 27 Feb 2012, 02:21 pm »
A Beresford DAC is a nice "entry" DAC that also includes a built in pre-amp (two sets of outputs, one fixed one variable) and a Class A headphone amp.  You get a lot of value from an entry level DAC and the sound quality is nice for the price.  There is one on Audiogon for $250 now (no affiliation).  I still use my Beresford in my second system.
John
navi
« Reply #5 on: 27 Feb 2012, 02:43 pm »
good idea! i like the simplicity of it- know any who has one?
firedog
« Reply #6 on: 27 Feb 2012, 04:56 pm »
The new MF V-DACII is a good one.
For $200 you can get the new Aune X-1, which has gotten some good reviews: http://shop2.hifidiy.net/index.php?main_page=product_info&products_id=106
rollo
  • Rollo Audio Consulting -
« Reply #7 on: 27 Feb 2012, 05:18 pm »
 The Musical Fidelity V-Dac with Pangea power supply will knock your socks off. If can spend a bit more the MF M-1 will please you more. Real sleepers these DACs.
 Music Direct or Audio Advisor have a thirty day return policy. Check them out Ka Boom for the buck.
charles
ProCast99
« Reply #8 on: 27 Feb 2012, 10:39 pm »
Wow - you've given me a great start -- thanks everyone!
gooberdude
« Reply #9 on: 28 Feb 2012, 12:31 am »
About a year ago I bought my first dac and spent $1K total because that's where the meat of the market was.  Lots to choose from, couldn't go wrong w/any of them (at that time).
Good & cheap dac's are plentiful & certainly a sign of the times.
OP - you probably can't go wrong with any of the dacs listed.
ProCast99
« Reply #10 on: 28 Feb 2012, 03:14 am »
Thanks Blair - your choices are always frugal!  This seems to be for transferring analogue to digital though -- would it function as a DAC if run in the opposite direction? Is it really that straightforward?
Seems kind of too good to believe... :scratch:
Niteshade
    • Niteshade Audio
« Reply #11 on: 28 Feb 2012, 10:57 am »
This DAC goes both ways. You can play from the computer OR record to the computer with it. It even has a built in phono preamp that can be switched on. I have two of them and they work perfectly but never tried the phono preamp.
kip_
« Reply #12 on: 28 Feb 2012, 02:56 pm »
The Schiit BiFrost DAC has received very favorable reviews both here and on 6moons, and it's $349, and upgradeable as well.
http://schiit.com/cart/index.php?main_page=product_info&cPath=0&products_id=7
doug s.
  • makin' music
