GAS Flea Market thread
ptman
Tributaries Cable Analog Interconnects
« Reply #520 on: 20 Jan 2020, 05:41 pm »
Tributaries Cable Silver.
3 pair 1m Balanced. $25/pair
2 pair 2m RCA. $10
« Last Edit: 23 Jan 2020, 04:42 am by ptman »
ptman
Transparent Audio and Video
« Reply #521 on: 20 Jan 2020, 05:47 pm »
1m and 2m optical. $15
3 2m video component RGB. 1 pair with BNC termination at one end. $15
1m and 2m HDMI. Likely 2.0. $15
« Last Edit: 22 Jan 2020, 07:36 pm by ptman »
ptman
Soundstring Power and Speaker
« Reply #522 on: 20 Jan 2020, 05:51 pm »
Sold
2 1m Soundstring Gen 1 Power Cable. Furutech Gold Plugs. $25 apiece
1 10ft Soundstring Gen 1 Power Cable with 20 amp IEC. Furutech Gold plugs. $25
1 pair biwire Soundstring Gen 2 Speaker Cable. 2 meter. $40
ptman
Various Monster Cables and Accessories
« Reply #523 on: 20 Jan 2020, 05:54 pm »
$5 apiece.
Various monster analog interconnects. 1m, 1m with video, 2m.
Monster Video Power filter.
2m Monster RGB (not pictured).
ptman
Bose AV48 Media Center - All the Bells and Whistles
« Reply #524 on: 20 Jan 2020, 05:56 pm »
Bose AV48 media center with CD, Radio, Music Hard Drive, 5.1 Acoustimass speaker system, VS-2 Video Enhancer, SL-2 Wireless transmitter for rear speakers, Universal Speaker Stands.
$350
Local St Louis pickup only.
« Last Edit: 3 Feb 2020, 04:18 pm by ptman »
sturgus
Re: Soundstring Power and Speaker
« Reply #525 on: 20 Jan 2020, 11:53 pm »
I will  take the 3 power cables. PM me.
ptman
Re: GAS Flea Market thread
« Reply #526 on: 21 Jan 2020, 02:10 pm »
PM sent
ptman
Re: PS Audio UPC-200
« Reply #527 on: 22 Jan 2020, 10:47 pm »
Sold
$40
PS Audio UPC-200 power conditioner. 2 outlets. Can be bridged for high-current.
« Last Edit: 27 Jan 2020, 02:57 am by ptman »
ptman
FREE - Local Only - Philips TSU7000 Remote
« Reply #528 on: 22 Jan 2020, 10:50 pm »
Philips remotes. Philips doesn't make remotes anymore, but if you have one already, this will make a great spare.
Will also provide Xantech emitter jumpers for controlling items in cabinet.
« Last Edit: 13 Feb 2020, 10:41 pm by ptman »
sturgus
« Reply #529 on: 31 Jan 2020, 02:08 am »
I have two sets of speakers and a set of tube monoblock amps for sale here in the St. Louis area:
Von Schweikert VR 33   $1250 for the pair    come with Herbies Audio Labs threaded stud gliders
Von Schweikert DB100  $1000 for the pair   had these for years but haven't used much as they are ultimately too large for my space. 100db efficient - can be driven by flea watt amps. Built in amps power woofers for bass -- bass level is adjustable.  Review on Soundstage. These are large and quite heavy -- but if you have the space - great speakers at unbeatable price.  (I only took a picture of one of them -- the other is identical and in the same condition)
Aronov Audio LS9100 monoblock tube amplifiers 110 watts per channel. I have also had these for years but haven't used them since about '08-09. I had them modded by Steve Huntley of Great Northern Sound in '05 -- basically a parts swap. I've included a pic of the document describing what he did. I know there are people in the St. Louis area that are familiar with these fine amps. They would not come with tubes or power cords. $850 for the pair. I have them currently stored - so no pics. If someone is interested I will pull them out and take pics.
Email:   [email protected]
PM sent
bpape
    • Sensible Sound Solutions
« Reply #530 on: 3 Feb 2020, 09:15 pm »
OK Guys.  After moving from my house with dedicated home theater/listening room to a 1 BR duplex I don't have room for some of my AV equipment. Some is older, some is newer.  Prices are dirt cheap or free.
2 GIK Acoustics Scopus T40 tuned membrane absorbers - Free - come pick it up. PENDING
2 GIK Acoustics Tri Traps - Black/black - Free - come pick it up. PENDING
1 GIK Acoustics Pillar Trap - previous version of the Soffit Trap but with wood top and bottom - Free - come pick it up. PENDING
1 Integra DTR 5.2.  Just composite and S Video.  Sounds pretty good though. Good piece for a 2nd or 3rd (maybe garage/shop) system.  Free - come pick it up.
Key Digital 3x8 Matrix video switcher - BNC connectors - component video only.  Great for a multi-TV situation.  Key Digital HD Leeza.  Quite the piece at the time. Now, scaling up to 1080p, great piece for the right person.  BNC connectors.  component video only no HDMI.  Again, not for everyone.  But if you want a top quality pro type scaler, this is it.  $50 for both pieces
Theta Digital Casanova pre/pro - component video only - no HDMI.  Very flexible setup options.  $50
Pair Snell K.5 large bookshelf.  Snell CR.5 matching center channel. One k.5 has a ding in one upper corner but they function perfectly.  $250 for all 3 pcs
And the beasts.....
Servodrive Contrabass sub.  2x active 15, 2x passive 18.  Utility cabinet.  115db at 14 Hz.  George Lucase uses these to master on.  Will throw in a Crown Micro Tech 1200 amp that will drive 1 ohm in parallel mono at 1200 Watts (about what the sub likes and has to have the 1 ohm capability)  Amp needs a bit of work.  Lent it out and he hooked it up as bridged mono when set for parallel mono.  $250 for all.  Over $2k new just for the sub.  Bring a truck or van.  This is big and heavy.
Acoustat Monitor amplifiers - $4k of mods done by Mike Savuto of analog associates. They have a small arcing issue (amps) at higher volumes with lots of HF content but have spoken with Mike and he has a fix for it.   Just a couple of diodes to be added.  Best Acoustats I ever heard.  Nothing like the transformer based ones.  These can be modified to run other ES speakers also.  Have the panels and bases also.  These are a drop in replacement for the Acoustat transformers.  Price is negotiable.  Contact me and we can talk.  Would be willing to deliver within a reasonable distance.  SOLD
Thanks for looking!
« Last Edit: 5 Feb 2020, 08:48 pm by bpape »
Bob in St. Louis
« Reply #531 on: 4 Feb 2020, 12:44 am »
Wow, there's a LOT of temptation there. I have no need, but I want to pack-rat.
sturgus
« Reply #532 on: 4 Feb 2020, 06:23 am »
And the beasts.....
Thanks for looking!
I can take the 2 tri traps and the 2 gik t-40's. When can I pick them up?
bpape
« Reply #533 on: 5 Feb 2020, 06:04 pm »
PM Sent
thunderbrick
  • I'm just not right!
« Reply #534 on: 5 Feb 2020, 07:38 pm »
I'd like the pillar trap, please!
bpape
« Reply #535 on: 5 Feb 2020, 08:45 pm »
PM Sent
justauby
« Reply #536 on: 17 Feb 2020, 03:02 pm »
Got a few items i'm selling.  Located in Lafayette Square St. Louis, i can come drop off up to an hour away.
ESS Heil AMT Air Motion Tweeter: $125.00 SOLD
Xkitz K231 Stereo 3-way Active Crossover: $400.00 SOLD
RADIAN 5215B-16 Coaxial 2-way w/ crossovers: $650.00
Klipsch K-402 Horn: $550.00 SOLD
« Last Edit: 12 May 2020, 09:39 pm by justauby »
slanted
« Reply #537 on: 18 Feb 2020, 10:44 pm »
Hi, I'm interested in the Heil tweeters. Please call or text as I'm not sure that I can receive pm's yet. Thanks.
Mike Mettes
314-749-7052
high figh
« Reply #538 on: 19 Feb 2020, 07:46 pm »
FREE Denon DL-110 high output MC cartridge. About two years old and very well cared for. Well until I damaged it, which is why it's free. I was doing maintenance on my turntable, and bent the cantilever down and aft with my sleeve. So they cost about $200-$300 new and to have it repaired is about the same. So I'm going to upgrade. But if anybody wants this to either repair or do a DIY project I'm giving it away. Its actually a good cartridge to get into moving coils with.
Cheers.
justauby
« Reply #539 on: 21 Feb 2020, 04:40 pm »
Mike Mettes
314-749-7052
Sorry Mike they sold.
