well, maybe an Amadeus when I can find an inexpensive used table)
Welcome.The square motor version you have is more correctly known as the Well Tempered Turntable."Classic" was the name given to the Transparent made round motored turntable.Interesting pictures.Why is the motor block so far inwards ?Is that a non-standrad belt ?Correctly placed, the motor block should sit flush with the edge of the turntable plinth.
Hi Vic,after i saw your photo,i think you need to adjust your counterweight,i mean the screw of the counterweight should place to 12 O'clock position,more balance.
Vic,Thanks for the information on the arm modifications. I'll try and track Jorge down.I also loved the photos of your gorgeous VW Beetle convertible. Is it a 1967 (the first year with a 12 volt electrical system and the last year with the old-style bumpers)? I drove Beetles for 19 years and helped pay for my undergrad degree in the 1960s by working on fellow students' Beetles. My last Beetle, and my favorite, was a cream colored 1967. I had to sell it in 1982 after my wife and I had a baby and needed a larger car. I still miss that car.Phil
Code, interesting. My friend has the same square motor deck with a Player style tonearm. Was there ever a differentiation between the two? The only belts I've been able to find are these narrower 1/8" belts which stretch over time. When they're new I run the motor closer to the plater, works just fine. Can't do that with the round motor.
Yes, the square cut-out does allow greater adjustment.Differentiation between ?The two arms ?The two tables ?
Hello Vic,The original Well Tempered turntable was never offered with the arm from the Record Player.Any such hybrid was probably the result of an original WTT sustaining arm damage and the owner deciding to replace the arm with a less expensive Record Player arm.
