Use a Barometer for SPL meter?
0 Members and 1 Guest are viewing this topic. Read 1539 times.
dwarfed centipede
« on: 24 Feb 2012, 08:54 pm »
Just had this idea today.  Is it possible to use a Barometer to measure changes in SPL?  I would guess maybe in a confined space such as a car it could work?  Any thoughts on this?
Mitsuman
  • Diamond Tone Junkie
Re: Use a Barometer for SPL meter?
« Reply #1 on: 24 Feb 2012, 09:29 pm »
A magnahelic gauge *might* work. It's used to measure differential pressure in inches of H2O.
Scott F.
« Reply #2 on: 25 Feb 2012, 12:27 am »
The trouble with both is you would need the cab of the car to be sealed to the point you could pull a vacuum on it. Any air leaks would throw off the readings. then again what you are reading is air pressure changes within that sealed cabin. The lower octaves will have the biggest effect on the readings. You'd be able to tell when bass notes are played but you wouldn't be able to differentiate what frequency it was. You wouldn't be able to measure treble (or at least I don't think so).
Then again, everything I just typed was a thought experiment and I could be wrong.
electricbear
« Reply #3 on: 25 Feb 2012, 03:11 am »
Just quit obsessing and just download the spl meter Iphone app :lol:
