Perhaps quite foolish of me, but no. Going to roll the dice. If they're only 3/4 as good as people say, I'll be happy given that you don't need to take out a second mortgage to buy them.
The Linkwitz Pluto is certainly unconventional. No pricing information though. Even so, he isn't far from where I live -- maybe I should arrange an audition.The Pluto looks like it needs subs. Is that right?
I don't understand what is meant by "pride of ownership". Being proud to have spent more money is an absurd proposition, although I'm sure there are people who feel this way.It turns out that there are real quantitative and qualitative differences between a 25K Acura RSX and a 50K Porsche Boxster, not just pride of ownership and fit and finish. The Boxster is a better car in every performance metric save fuel efficiency.But I think I've decided. The Vapor Cirrus will be my next speaker. Time to start saving pennies.
It's sort of turning into a Cirrus fan club here. I haven't heard anyone say anything negative about them. And at a $3700 starting price, it seems hard to go wrong.
I just don't get the monitor thingQuote
The nice thing about monitors is flexibility. I had these monitors doing magic in my main rig and now have them on my desktop. Can't do that with a floor stander.
I don't see the purpose of a small monitor (especially an expensive one) unless you have a recording console or use it on a table with your computer. As long as you have the midrange and woofer doing the same thing (2-way) you will have intermodulation of the midrange from the woofer (along with compromised bass). When you have a 3 way you can have separate woofers that use a separate amp and you can easily equalize the bass too. The Behringer Inuke 3000DSP costs $400 and gives 400 watts a channel and has a built in xover for the bass and 8 bands of equalization. Have you ever heard bi-amped equalized bass? Imagine plus and minus 1 db from 25-300hz....talking about clean sound! No bass nodes at your listening position...none! "Wow" is what most people say after equalizing the bass in their room. Also not having the bass run off the same amp gives you no back EMF from the woofers that would also mess up the midrange. And then there is the cabinet thing. If you have a 3 way then you can put the midrange on an open baffle thus eliminating the air pressure behind the midrange. As long as you have the midrange in a box (no matter how good the box is made) there is the air spring that the driver is always fighting. A monitor on a stand does not take any less room then say 3 of Danny Richies 8 inch servos woofs on an open baffle with the mid and tweeter above. Same amount of floor space. I know monitors are cute but for pure performance an open baffle midrange and biamped equalized bass would be mucho better. I know Danny has such a design in the works and that is what I would go with in a heartbeat over any monitor, no matter what drivers were in it. I just don't get the monitor thing. Ok, someone had to say it. Now back to your regular program.
Don't get me wrong. I am a floorstander type of guy. More so a dipole, planer, type of guy. But monitors have their place. However if I was spending north of 20 grand for speakers you can bet it would not be for monitors. Why, because size does matter. At least in audio that is. There, someone had to say it again. Rocket_Ronny
I sent Ryan an email last night asking about how long the lead time is, what bang-for-the-buck options he recommends, etc, but haven't heard back yet. Will update this thread when I place the order.
