One of my favorite product photos
Niteshade
    • Niteshade Audio
« on: 16 Feb 2012, 12:12 pm »
Last year a few people were recommending methods on how to take photos. One of them was to take shots outside. Here is one of my favorite stock photos of a NS-40 sitting out on the back patio.
decal
Re: One of my favorite product photos
« Reply #1 on: 16 Feb 2012, 01:25 pm »
Crop everything except the equipment and it would be a nice pic, just my opinion.
Niteshade
    • Niteshade Audio
« Reply #2 on: 16 Feb 2012, 02:11 pm »
That is a stock photo and I will work on it eventually. It was done for experimentation. I can't believe what a difference going outside made. It was an overcast day which I think helped some.
JohnR
« Reply #3 on: 16 Feb 2012, 02:59 pm »
The diffuse lighting does look much better! :thumb:
To remove the background distractions, perhaps try a sheet of cloth that extends beyond the boundaries of the photo, I like a material with a very coarse weave.
Using a smaller aperture helps too.
thunderbrick
  • I'm just not right!
« Reply #4 on: 16 Feb 2012, 03:11 pm »
I shoot products part-time pro.  Send me that unit and I'll REALLY give you some nice images.
You'll have the files in a few days, no charge.  Returning the amp will take slightly longer.
thunderbrick
« Reply #5 on: 16 Feb 2012, 03:24 pm »
Get one of those reflective shields that goes on your car's dashboard.  Keeping it out of the photo, set it up so that it reflects light on the BACK of the amp.  It'll add a little definition and make the amp "pop" from the background.  You'll also see more detail in the transformers.
I'll PM you with my shipping address.     :icon_twisted:
nathanm
« Reply #6 on: 16 Feb 2012, 03:27 pm »
This video may help out.  It's shooting a coffee maker, which has similar reflective properties to a tube amp:
http://www.youtube.com/user/prophotolife?blend=2&ob=1#p/u/14/OxDG3WDT7Kw
nathanm
« Reply #7 on: 16 Feb 2012, 03:49 pm »
thunderbrick
« Reply #8 on: 16 Feb 2012, 05:15 pm »
Showoff!  :lol: :thumb:
I guess that means I don't get that amp to shoot? :duh: :lol:
decal
« Reply #9 on: 16 Feb 2012, 05:43 pm »
That's "more better". :thumb:
Niteshade
    • Niteshade Audio
« Reply #10 on: 16 Feb 2012, 11:27 pm »
Showoff indeed! :thumb:
Thank you- that truly looks spectacular.
I will try some outdoor props to see what can be done.
It's disturbing to make something and not be able to capture how good it looks.
djbnh
« Reply #11 on: 16 Feb 2012, 11:53 pm »
In situ. Blair, the one you posted has a diff. wood wrap, I think, from this one.
Niteshade
    • Niteshade Audio
« Reply #12 on: 17 Feb 2012, 02:44 am »
Extremely good photos!
The wood wrap shown is their standard quality. The one in your photo is a very high grade. The difference shows up as a more defined pattern density. (More stuff going on and clearer.)
djbnh
« Reply #13 on: 17 Feb 2012, 03:12 am »
Exactly, Heirloom birdseye maple, as requested.
Niteshade
    • Niteshade Audio
« Reply #14 on: 17 Feb 2012, 12:39 pm »
Wood Selection: http://www.delnero.com/custom-made/wood-furniture.html
This is a good time to bring up the selection of wood at my disposal. There is a direct link to the site on another post, however it does not mention the differences between, say Heirloom and Artistic selections. Artistic wood typically does not have a pure pattern. In another words, it may have streaks, different colors etc.. Heirloom branded wood will have a more pure look to it. The color will be more balanced and there will be fewer artifacts.
There is a third feature of wood, which is being mentioned here. This has to do with pattern intensity and uniformity. The photo shows a light pattern while David's shows a heavier one. I like them both. If someone wants a specific pattern or grade, let me know. There may be a minor upcharge since they'll have to search through the wood more carefully.
rklein
  • My finest audio piece ever!!
« Reply #15 on: 17 Feb 2012, 02:38 pm »
I am still very happy with my wood selection for my NS-60 SE(check out Blair's avatar) and my Beacon III.  :thumb:
Randy
djbnh
« Reply #16 on: 17 Feb 2012, 10:01 pm »
Looks like quilted maple - that works, too.  :wink:
gooberdude
« Reply #17 on: 17 Feb 2012, 10:12 pm »
I've chosen the Artistic Butternut on the upcoming preamp.   I don't usually go for crazy looking grain, but with wood sides only on the Beacon II, it might look cool.
It would be something else to see an amp in the dark blue color that djbnh made popular, and wrap it in some of Delnero's Reclaimed wood that has wild colors enfused.
thunderbrick
« Reply #18 on: 17 Feb 2012, 10:26 pm »
Here's an option:
Get a 4x8 sheet of white matte Formica.  Secure one end to 4x4 plywood sitting on saw horses, and lift the other end up in a slow curve behind the amp.  Do all that in open shade, and Voila!  Instant budget studio, and no distracting details in the Formica that need to be photoshopped out.  I'd suggest slightly overexposing the image to keep the bright background from UNDER-exposing the amps.
Nathan, you OK with this idea?
'brick
