Inside the Techie
0 Members and 1 Guest are viewing this topic. Read 3460 times.
jostber
Inside the Techie
« on: 15 Feb 2012, 06:56 pm »
I have upgraded the bearing for my Technics SL1200 MKII turntable and then removed the plastic cover that is above the circuit board. If one look at the inside the TT there is some room available:
Would it be an idea to have some kind of resonance absorbing components in the plinth or would that be futile? F.ex. dampening of the circuit board in some way?
Herbie
    • Herbie's Audio Lab
Re: Inside the Techie
« Reply #1 on: 15 Feb 2012, 11:15 pm »
A little rope caulk wouldn't hurt, and would probably be beneficial.
Herbie's Audio Lab
jostber
« Reply #2 on: 16 Feb 2012, 11:53 am »
Ref. to this post from previously, would some Grungebuster stuff work here?
http://www.audiocircle.com/index.php?topic=93032.0
I guess the main PCB board where the direct drive motor is would be the important part to isolate.
Æ
« Reply #3 on: 16 Feb 2012, 04:03 pm »
I just hate it when people say "Dampeneneneneing." To dampen is to ing. Dampen and Damping will do just fine.
Get some peel and stick variety of damping sheet material. You can cut it with scissors and stick it wherever you need it. PartsExpress sells a very affordable generic version, otherwise go and buy some Dynamat.
jostber
« Reply #4 on: 19 Feb 2012, 08:10 pm »
Thanks. :) Wrote that post a bit quick, meant to say damping of course.
