0 Members and 1 Guest are viewing this topic. Read 12162 times.
Closed
Will the Shure 840's and the Audio Technica M50S both be good for use with iPods or iPads?
FWIW I'd not recommend the ATH-M50s, unless you like your bass boomy. Boom boom boom. Hm... it just occurred to me, that perhaps there is a correlation between the type of speakers you prefer, and the type of headphones you prefer... hm....
I would say that your theory about headphones and speakers are not accurate in my case. I own the ATH-M50s and I have changed my audio settings on my Cowan J3 a bit to the "leaner" side of bass. The M50s for what I use them for are stellar. I don't consider myself a basshead and my speakers are the TRT model from Selah Audio which are rated at 45hz - 20K (+2/-3db).
"Theory" might be overstating - more an off-the-cuff speculation. However, your speakers are closed, and you prefer closed headphones. I rest my case (flimsy though it may be)
I never stated that I prefer closed headphones. I was just responding to a question of why I have the ATH-50S's in the first place.
I don't use headphones in planes or trains and advise friends against it - the background noise level is high so it's very easy to have the playback level at damaging levels without realizing.Noise-cancelling phones would be different I suppose, although I've never used them.
I don't think noise cancelling phones are as effective as Etymotic Research ER4S, which have 35 - 40dB of ambient noise rejection and sound good at the same time. http://www.etymotic.com/ephp/er4.htmlI use them and can play music quietly, because of this rejection figure. The problem with noise cancelling phones is they tend not to sound good! Ooops! As well, their effective ambient noise rejection is inferior to something like the Etymotics. I do think that reasonable compromise can be found in sealed-back headphones, though, and these can be more convenient and comfortable than having something deep in your ear canal - this wears thin after 3 hours or so.
I also assume that you can't return them once they've been used
Good info about the IEMs. I have never used a pair because I assumed I would find them horribly uncomfortable. I also assume that you can't return them once they've been used Jason seems to have abandoned this thread, though, in which he did ask for over-the-ear phones.
