0 Members and 1 Guest are viewing this topic. Read 4293 times.
Do you have a proposed floor plan? That would help a lot, especially if it shows where you plan to put the speakers, the seating, the wall opening, etc.
and you certainly don't want any foam in your walls!
You really do need both the inside and outside barriers. So the best plan is to build normal walls as usual, then apply appropriate treatment on the inside, within the room...
This product: http://www.owenscorning.com/around/sound/products/solserene.aspwould be a great idea to cover a wall that has acoustic treatments, especially people using the LEDE concept. Would look MUCH better.
