FS: McCormack LD-2 line stage preamp (Near New)
0 Members and 1 Guest are viewing this topic. Read 4170 times.
Freo-1
« on: 3 Feb 2012, 11:34 pm »
Up for sale is a near new McCormack LD-2 line stage preamp.  This unit is less than a year old, and has been used very lightly.  It was intended for use in an HT setup when only two channel stereo reproduction was used.  Unit is rated 9 of ten cosmetically, looks as new.  All original packing, manual, and remote included.
There are 5 line level inputs: CD, VIDEO, TUNER, TAPE, & PH/AUX.  The unit sports an advanced Burr-Brown volume control, which increments in .5 db steps.  Also supports theater bypass mode when using a multi channel processor.  Unit is solidly built, with very high quality parts throughout.  Suppots two preamp out for biamp operation.
The original retail price of the unit is 2499.00.  Asking 899.00 shipped via paypal to lower 48.
Pictures upon request.
Specs:
•   LD-2 Line-Stage
•   Gain: 20 dB
•   THD: less than .1 % at 1.0 v rms out
•   Hum and Noise: 100 dB below 2.5 v rms out
•   Dimensions: 19"W, 3.5"H, 11.25"D
•   Weight: 18 lbs.
LD-2 Optional Phono Stage (Not Included: Available from McCormack)
•   Phono Sensitivity (Selectable):
•   low gain: 5mv input for 0.5v output @1kHz
•   high gain: 0.9mv input for 0.5v output @1kHz
•   S/N:
•   low gain: -80dB relative to 10 mv input
•   high gain: -75dB relative to 100 mv input
« Last Edit: 3 Apr 2012, 08:58 pm by Freo-1 »
Freo-1
Re: FS: McCormack LD-2 line stage preamp (Near New)
« Reply #1 on: 14 Feb 2012, 12:58 am »
Bump.
Price lowered to 925.00  Unit is as new.
You will not find a better sounding preamp at this price.
« Last Edit: 10 Mar 2012, 04:38 pm by Freo-1 »
zeke
« Reply #2 on: 14 Feb 2012, 04:50 am »
have any idea what the output impedance is ?
Freo-1
« Reply #3 on: 15 Feb 2012, 12:46 am »
Yep.  It's less than 100 ohms (from the owner's manual).
Freo-1
« Reply #4 on: 28 Feb 2012, 10:27 pm »
Weekly bump.  You will not find a better price for a very high quality unit as this.
Freo-1
« Reply #5 on: 2 Mar 2012, 07:44 pm »
Picture of what unit looks like...
« Last Edit: 10 Mar 2012, 05:04 pm by Freo-1 »
Freo-1
« Reply #6 on: 10 Mar 2012, 01:40 pm »
Weekly bump.  Price dropped to 925.00
Would also consider a swap of this for a First Watt amp.
« Last Edit: 10 Mar 2012, 04:39 pm by Freo-1 »
Freo-1
« Reply #7 on: 3 Apr 2012, 08:47 pm »
Bump.
Price lowered to 899.00
PhillipC
« Reply #8 on: 5 Apr 2012, 04:24 am »
PM sent
Phil
Freo-1
« Reply #9 on: 9 Apr 2012, 12:14 am »
Item has sold.
