0 Members and 1 Guest are viewing this topic. Read 18769 times.
DOH - sorry for taking this thread off-topic; that was not my intent. I forgot to ask, do these Rythmik subs utilize the new HP amp @ 600 watts as opposed to 370?
Yes, it is the H600-PEQ3 and I assume the DS1510 Driver, although the DS1505 looks identical on the exterior.
Wow - even better! Jeez...what a setup you have.
How much was it for the two subs? I am considering the same set-up you have and I am wondering how big of a change there is between the ST's vs. ST's with dual subs.Thanks,Kevin
Well my 2nd Sub has arrived!All I can say is WOW! I was expecting some improvement, maybe 25% subjectively, but I would call it close to 200% in reality. The 2nd sub really evens out the bass and energizes the entire room (6000+cuft due to open floor plan and cathedral ceilings). I was really happy with the single sub, but adding the 2nd is an entirely different deal - just amazing.Thanks again to Jim and the crew at Salk for a fantastic job! I couldn't be happier with the result.Tom
Dual subs is certainly a necessity
Brian offers my woofers as well: http://www.rythmikaudio.com/GR_drivers.htmlBrians observations posted on his site: Driver comparisonHere is his metal cone version: http://www.rythmikaudio.com/DS1200driver.html
Danny---Is there a cabinet maker offering a box for a double 12" GR driver/Rythmik 370 amp combo? And do you offer drawings for such a cabinet (3-4 cu.ft.)---Eric.
Ooh, that would be great Danny. But I'm going to have stereo subs, so I would need four of the 8 ohm drivers, two per side. You have the two only, eh? Thanks---Eric.
Ah, so I see.....I would have two boxes per side, each containing a 4 ohm 12" driver, the two powered by the upcoming dual-channel Rythmik amp. For stereo, I would need one of these set-ups on each side. Or to get two 12"ers per side right now, I could just get four F12's, and stack them two high on each side. I was under the impression that I could presently get two cabinets, each containing a pair of 8 ohm 12" GR drivers powered by a 370W Rythmik amp, a dual F12 in otherwords. I didn't know that the Rythmik amp's servo-system would not work with two drivers. Never mind! And thanks for setting me straight.
