0 Members and 1 Guest are viewing this topic. Read 12646 times.
Berni - I did the Chesky test because I felt that the soundstage was a bit constricted while listening to my usual go to CDs. There are some phase tests on the same CD but I was not able to hear a notable difference between their in-phase and out-of-phase recordings. You are right about the visual effect of the large panels.
OMG...the difference little things make. I had a couple of hours today to play with this again, so I decided to try some small things that people recommended. I closed the door to the opening on the right wall and removed the absorption panel from the left wall. So now there is actually a reflecting surface on both right and left walls for both first reflection points and bingo! The soundstage is wider, the Chesky recording extreme right and left images are credibly where they have to be...no snapping back to center.
