I would question the need for that flat panel behind the woofer magnets - the vertical in the last picture looks like it would interfere with the sound less and could still be made to perform the same function - unless I misinterpret its function.Russell
Welcome, gamgee. I would say you are off to a good start. I would question the need for that flat panel behind the woofer magnets - the vertical in the last picture looks like it would interfere with the sound less and could still be made to perform the same function - unless I misinterpret its function.Russell
Magnet mounting I'd say.........although it'd need to be beefier than the drawing to be really effective.Is that a fullranger on top? I would try to isolate the fullranger from the woofers as best as you can........full separation is best, to keep the vibrations from the woofer from affecting fullrange. I'm doing that with my dipoles and its one of the biggest improvements I've made. Magnet mounting the woofers also seemed to "tighten" up the bass quite a bit.I like the "naked" fullrange version the best! Although you would for sure need some sort of active eq. Better yet, hang it from swings and get it isolated from the rest of the speaker and you're onto something.......
Tweeter: Beston RT002A Ribbon Tweeter modified for dipole operation http://www.parts-express.com/pe/showdetl.cfm?Partnumber=277-112After finding this driver on part express, I contacted Beston and found they are really cooperative, fast and allround pleasure to work with - they promptly accepted the idea of open back and sent me my pair without extra charge - I have the first such pair they made!
Hi gamgee.IMO you can’t do better than a sand filled woofer baffle.In one location I have a true infinite baffle for the bass. 6 X Kef B139s in a concrete floor 150mm thick over a large garage.I have also used a baffle about 2m X 2.5m with a 100mm thick filling of sand.The concrete mounted woofers, with low and powerful enough signals, can vibrate the whole 6m X 8m floor. I believe that concrete may be inherently underdamped. It can ring.The sand filled baffle never vibrated under any conditions… not at all…not even the slightest.(I followed Gilbert Briggs’ Wharfedale OB idea of course).And that was without magnet mounting, which might even be better.Regards,David
Now this I am excited to see! Could the little "horn" be cut away (or removed) to make the assembly smaller?
Now I'm interested why you want to remove the faceplate/waveguide (since it improves dispersion)?Is it because you want to reduce the area around tweeter some more? Without waveguide you will get aproximately 1 cm off around the tweeter...
To reduce the area, yeah. In my case I run the drivers 'naked', suspended from wires (with a Neo3 tweeter). The idea is to push the dipole directivity as high as you can, so smaller is better here. With a tiny 'baffle' the dipole peak is pushed higher, dictating when the driver starts to beam. The horn isn't need for controlling the directivity, as the behavior of the dipole does this itself.
Yes, let us know how the Bestons are, nice find.I also think that the Visaton BG20 is a find. You have probably read the German Klang + Ton 'Cheap Trick' where they used the BG20 successfullyin a qouple of variations for an only cone speaker, tweeter, mid and bass all the way. The BG20 was crossed at 300 Hzand 3.5 kHz with no other correction applied for a revealing mid, that should be about optimal also for you, I think./Erling
