Recommended speaker cables for Vandersteen 2ce Sig II
0 Members and 1 Guest are viewing this topic. Read 17169 times.
zuluwarrior0760
Re: Recommended speaker cables for Vandersteen 2ce Sig II
« Reply #20 on: 11 Jan 2012, 05:28 am »
I owned 2CE Signatures for 10 years.  I recently moved to a much larger
room than before and upgraded to Revel Studio 2's
I ran Kimber 8TC with my Vandersteens until I upgraded all my cables about 1 1/2 years ago.
I listened to many bi-wire cables and interconnects and settled on Grover Huffman cables.
http://www.groverhuffman.com/
An 8ft pair would be around 700 or so as I recall.  They have a fair amount of break-in but when
all was said and done, they bested anything I had heard up to that point under 2K and I listened
to a lot of cables.
Hang on to those speakers.  They are the best you can find under 6K
anonymoustao
« Reply #21 on: 12 Jan 2012, 11:31 pm »
to a lot of cables.
I've seen Grover's cables mentioned on the SH forums.  I'll look into them, too.  Thanks!
I figure I may as well enjoy the auditioning process for cables, and use it as an opportunity to become a better listener.
I can only promise to hang to the speakers for the next 2 years.  Beyond that, I'll probably try something else, even if I end up sticking with the Vandersteens.  :)
Right now, the missing amplification from my life is my biggest problem.  And that needs to rectified tout suite.
