List of DACs "Under $450"
0 Members and 1 Guest are viewing this topic. Read 102841 times.
fredgarvin
Re: List of DACs "Under $450"
« Reply #120 on: 27 Mar 2019, 09:29 pm »
Burson has a new DAC/HP amp for $399. Called the Swing, it features swappable op amps as their Amlifiers do. What a nice way to tailor the output for the sound you want.
https://www.bursonaudio.com/products/swing/
bladesmith
  • water quenching steel since 2001....
    • palmer knives
« Reply #121 on: 28 Apr 2019, 05:33 pm »
Can anyone tell me what kind of voltage this
Unit requires..to power up and  run..?
Thanks.
« Reply #122 on: 28 Apr 2019, 05:41 pm »
Looks like it would use a 12VDC wall-wart.
Is that a computer power connector in the back?
sresener
« Reply #123 on: 28 Apr 2019, 06:32 pm »
Not sure if it was mentioned the version 2 smsl su8 is pretty decent, it has a remote, rca and balanced outs, its a preamp and  has usb, coax and optical inputs. And it was unanimous with 4 people that it sounded better than my buddies nad c658 and one of the 4 people was the owner of the nad.  :(
fredgarvin
« Reply #124 on: 28 Apr 2019, 06:46 pm »
Thanks.
If you mean the Swing, it comes with a 12v supply.
https://6moons.com/audioreview_articles/burson2/
bladesmith
    • palmer knives
« Reply #125 on: 28 Apr 2019, 06:51 pm »
So, a user should be able to modify
A large 12v battery to supply power,
Instead of the supplied power cord..?
V..
mresseguie
« Reply #126 on: 28 Apr 2019, 07:35 pm »
Bladesmith,
Welcome back! It’s been a while.  :)
Michael
