iPhone/iPad Frequency Measurement App
0 Members and 1 Guest are viewing this topic. Read 11183 times.
pslate
« on: 4 Jan 2012, 05:27 pm »
I noticed there are several apps now available on either the iPhone or iPad for the measurement of frequency response. Has anyone had good luck with an app in particular? I am looking to take some measurements, but I was not sure if the iPhone or iPad hardware and app are up to the task of basic measurements. I have not taken measurements before, so basic advice is also welcome :thumb:
Have a good afternoon
*Scotty*
Re: iPhone/iPad Frequency Measurement App
« Reply #1 on: 4 Jan 2012, 06:50 pm »
RTA Lite is pretty useful, but it will not serve as substitute for a calibrated microphone and a good PC based measurement suite. No stand alone app that uses the internal mic in the iPhone will be very accurate. The mic and the programing that makes the mic suitable for voice pickup outdoors conflicts with the need for the mic to have a flat response in the bass region. The programing is non-defeatable.
 RTA Lite has accuracy issues in the bass portion of the audio spectrum for the aforementioned reasons. It is difficult to get consistent measurements below 200Hz. If you check my galleries you can see a couple of screen shots of measurements of my system at the listening position using pink noise and RTA-Lite. It will tell you about big problems but you will probably not see smaller ones due to a lack of resolution.
Scotty
pslate
« Reply #2 on: 4 Jan 2012, 07:50 pm »
Thank you Scotty!
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #3 on: 5 Jan 2012, 03:41 am »
AudioTools from Studio Six
dave
davidandleigh
« Reply #4 on: 8 Jan 2012, 10:13 pm »
With the hardware module available from Studio Six Digital (iAudioInterface) do you think this starts to approach the other PC based solutions.  At $400 for the newer iAudioInterface2 I would hope this would rival the other solutions and of course work on an iPAD.  Has anyone used this module?
