Is it really that bad to stack the battery power supplies?
0 Members and 1 Guest are viewing this topic. Read 2544 times.
tapesonic
Just wondering if it really is that harmful to stack the power supplies?... 'cause my setup almost dictates that I do for space reasons. Thanks.
Vinnie R.
    • http://www.vinnierossi.com
Re: Is it really that bad to stack the battery power supplies?
« Reply #1 on: 4 Jan 2012, 05:41 pm »
Vinnie R.
« Reply #2 on: 4 Jan 2012, 05:41 pm »
Hi tapesonic,
Welcome to Audiocircle and the RWA forum!
I don't see any problem in stacking our units.  There are no transformers inside, so there is not inductive coupling / interference to be concerned about with batteries.
Stack away!  8)
Vinnie
tapesonic
« Reply #3 on: 4 Jan 2012, 09:34 pm »
Thanks for the reply. I was referring to the external power supplies specifically. I think your instruction manual stated to NOT stack them.
Vinnie R.
« Reply #4 on: 4 Jan 2012, 11:23 pm »
Hi tapesonic,
Are you referring to the external battery chargers?  If yes, then correct, I do not recommend stacking them.  They through out a fair amount of heat, and need their space to breathe.  I also recommend locating them away from the components, interconnects, etc.
Best regards,
Vinnie
