0 Members and 1 Guest are viewing this topic. Read 8384 times.
JIf you have an Iphone or Ipad the IPENG apps allows you to control the squeezebox software from your chair. It is great. Keep us informed on the travels and I dont think you can go wrong with the TouchDavidPS I love to read your e mails on Tebow
Thank you very much for the response. I was leaning towards a Touch but wanted to make sure I wasn't making the wrong move. I've owned cables from Bolder and had a modded Dio back in the day, and have always thought highly of Wayne's work. I will most likely get the Touch and send it in for mods after I listen to it in unmodded form. I have a modded SB3 with original switching PS and it sounds okay. Certainly not audiophile but good for background music. I love the convenience and would like to step up to a better sound quality. Thanks again!J
Wayne:I don't think you can load Android apps on a Fire. I considered getting one and went to the SB forums to find out it isn't easy to do. You have to hack the Fire to get an Andoid app on it.Chris H.
